Re: help sat in layby
Posted: Sun May 01, 2011 7:55 pm
The screws supplied with the LCA's are A4 stainless and are more than good enough for the job.
They are the correct size for the hole you drill and the alarms are calibrated to suit the supplied screw.
If you fit a screw of a differant size or material you will be inviting problems.
The screws/alarms only play up when somthing is added to the coolant (bar leaks/steel seal etc)
New coolant can also cause the screw to get coated. Some coolants lay down a protective layer on the inside of the whole cooling system when first added,,,,,this can cause problems for 2/3 weeks....after that a quick clean or a new screw (supplied by me) will fix it for good.
It is a small price to pay for the early warning it often provides.....see the testimonials on the shop home page (link below) some of the peeps who have posted on this topic have testimonals on that link.
Well over 3000 Bongos have alarms fitted.....very few problems reported and dozens of cases of the alarm warning of coolant loss long before any damage is done.
