brake pipes
- Bongonaut
Re: brake pipes
where do I get photo shrink tried some programs still wont let me post it
Re: brake pipes
http://www.picresize.com
This should do it
This should do it
- Bongonaut
Re: brake pipes
still not letting me post telling me its to large down to a postage stamp will give up on this one its Friday
Re: brake pipes
PM sent Email me the picdavepickering wrote:still not letting me post telling me its to large down to a postage stamp will give up on this one its Friday
- Bongonaut
Re: brake pipes
sent email but it wold not let me do it in PM section
Re: brake pipes
Nothings come through check the address in the PM?
- Bongonaut
Re: brake pipes
is this your normal email or a bongo email addresswinchman wrote:Nothings come through check the address in the PM?
- Bongonaut
Re: brake pipes
Got it, but I can't upload it either?
1st job, wd40 ideally overnight
Cut the steel pipe off flush to the top of the nut and use a 6 sided socket to remove nut, watch out as some are 10mm some are 11mm and the odd one will be 7/16" sometimes you have to knock them on with a hammer.
If that rounds it off, Mole grips or stilsons assuming you can get a pair in I couldn't on mine. Then its time for the magic tool the rounded nut removal socket.
Just had exactly the same issue on my Discovery had to do it on both sides of the front brakes.
I would replace the flexi hose at the same time as they are less than £15
Its not difficult just time consuming and having the right tools helps.
Good luck
Good luck
- Bongonaut
Re: brake pipes
thanks winchman already wd 40 sprayed twice will be on to it tomorrowwinchman wrote:Got it, but I can't upload it either?
Good luck
Re: brake pipes
Take your time, may need to hold the end of the flexi hose still whilst you undo the nut
Re: brake pipes
So how did it go?
- Bongonaut
Re: brake pipes
will keep you posted winchman had to take the wife out yesterday and got heavy rain to day
did borrow a set of callipers and checked the large nut size on the back plate was 23.76mm so got hold of 24mm socket so that's one problem sorted on to the next
- Bongonaut
Re: brake pipes
cancel that last post size of socket is 23mm not 24mm reading was 23.07 (need me glasses on next time)
- Bongonaut
