Page 3 of 13
Re: Cardiff - Starting & coolant loss problems
Posted: Mon Dec 25, 2017 9:21 am
by cutlass
for next - if you dont want delete air from "apendiks pimp" - take cuprum tube from "home air condition" and t-piece -than connect "apendiks tube" and "way in" of "cooling tank"....Image
Posted: Wed Dec 27, 2017 10:05 am
by TheLongRoad
From the picture it looks like the idea is as coolant expands it gets pushed out and into the plastic bottle, on cooling down the contacting water creates a symphon to draw the water back into the system. Thus avoiding having to top up regularly. But then again I could be totally wrong :roll:
Posted: Wed Dec 27, 2017 11:45 am
Its a sealed system, otherwise you can't create the necessary pressure to increase heat transfer, so no way can it be a syphon process as that requires that the syphon container to be open! The above picture just appears to me to be a collection bottle, so if the pressure cap opens the water is stored in the bottle and can be manually poured back in if required or just simply work as an indicator that you have over pressurised...
Posted: Wed Dec 27, 2017 1:40 pm
by haydn callow
Yes but, he’s talking about the T junction to the left of the tank..what’s that for??
Posted: Wed Dec 27, 2017 1:44 pm
by cutlass
NO! all wrong...I talk about connect that Image and "way in" cooling tank...use T-connector Imageand cuprum tube Image
after that you be onlu pour antfreeze on tank and dont open cap at "apendiks tube" and air be delete autonomously
Posted: Wed Dec 27, 2017 1:48 pm
by cutlass
for next - if you use bongo in wery hot climate - use that idea - delete "U-pipe" and do "line" cooling sistem https://www.drive2.ru/l/475280944610148836/
Posted: Wed Dec 27, 2017 8:18 pm
by the1andonly
haydn callow wrote: Wed Dec 27, 2017 1:40 pm Yes but, he’s talking about the T junction to the left of the tank..what’s that for??
I believe the t piece is connected to the end of the bleed tube. An automatic bleed process?
I'm with Geof that the bottle Is for indicating an over pressure, I have one with a float switch connected to an Led in the cab.
Posted: Wed Dec 27, 2017 10:53 pm
by cutlass
An automatic bleed process? - yes! =D> Am sorry - I dont speak werry well :(
Posted: Thu Dec 28, 2017 10:49 am
by Katka
Is the self bleed idea Cutlass has developed the similar to this thread? viewtopic.php?f=3&t=73975&p=694780&hili ... pe#p694780.
Posted: Thu Dec 28, 2017 11:05 am
by haydn callow
Instead of having a bottle to catch overpressure coolant......just extend the black outlet pipe and put it through the bulkhead so that if it over pressures it sprays over your feet.....instant warning that you cannot ignor !!!!😉😉😶
Posted: Thu Dec 28, 2017 1:29 pm
by cutlass
it bottle use at hot summer, after "hard-fast drive" - when you stop engine - antifreeze may local boil in engine - caps valve be open - antifreeze may go out....next situation - if you crash head engine-for go home you must delete termostat and open lowermost gasket of cap cool tank - bottle be catch antifreeze
Posted: Thu Dec 28, 2017 1:46 pm
by cutlass
for next - if in "long trip" cooling sistem leak - and you dont have "stop leak" Image - I use mustard Image- mix with antifreeze and pour into radiator
Posted: Thu Dec 28, 2017 1:49 pm
by cutlass
Katka- =D> it is similar idea - thank you! but I dont pave pipe across through the salon bongo
Posted: Wed Jan 03, 2018 9:30 pm
by cutlass
check glow plug and install transparent tube (from moto) on fuel pump - check air into fuel...
Posted: Thu Jan 04, 2018 5:49 pm
by haydn callow
Look on the bright side.......what would have been the result if you had no coolant alarm??
