Re: power in france
Posted: Sun Apr 03, 2011 6:49 pm
maxheadroom wrote:Reverse polarity can be an issue and most camping equipment shops can sell you a small polarity tester and a 'rewired' adapter to correct any reversed polarity supply. If you ask the shop's advice, they will sort you out with everything.
One of these
And then 2 of these with one wired opposite.....
Onsite..... plug in adaptor & lead ....check with your tester and if it shows up as reversed polarity then plug the other adaptor in.....sorted....
Quick tip...... put some insulation tape around the cable of the reversed adaptor....
