Page 4 of 18
				Posted: Thu Apr 05, 2007 6:45 pm
				by haydn callow
				O>K> How about this.. Your temp gauge sits on zero before you start up co's the engine is cold therefore so is the sensor. You start up and it slowley rises to the 11 o clock co's that is what the engine is doing. At about this point the system pressurises and unless you start flogging the engine or it is a hot day or whatever the temp stablises at this point. Remember the bypass pipes go from the cyl head to the expansion tank then out of the tank to the TOP of the rad then back to the cly head via the top hose. A certain amount of cooling takes place at the top of the rad.
				Posted: Thu Apr 05, 2007 6:50 pm
				by francophile1947
				This is a guess, but seems to explain your query Mike.
The temperature gauge probably only reads over a limited range, so it probably doesn't register anything until the water reaches (say) 65-70 degrees. If this is so, it will show nothing until this point is hit and then climb quickly to it's normal temperature. Anybody know??
				by haydn callow
				mikeonb4c, Hi there, if like you think, the needle on your guage "kicks off" co's your stats opening your bottom hose would get hot. It dosn't so it carn't be open. franco..I think you could well be right about the way the gauge works.
				Posted: Thu Apr 05, 2007 6:51 pm
				by alphabetter
				mikeonb4c wrote:And then there is this.  If the thermostat only opens occasionally, when the engine is really heat stressed, what is it that causes my temp gauge to stay on the cold stop for 5 mins then visibly kick off and move up to 11.00 o'clock.  I had always assumed it was a classic thermostat opening symptom but I now need another explanation
I think this is quite easy to explain - the left stop on the temp gauge clearly isn't 0C and probably isn't 25C it is more likely to be around 60C - so all the time your Bongo is warming up to close to its operating temperature the temp gauge will read 0.
				Posted: Thu Apr 05, 2007 6:55 pm
				by Harry
				That bit makes sense!
				Posted: Thu Apr 05, 2007 7:09 pm
				by Peg leg Pete
				If I remember correctly before Mike changed his thermostat, his temp guage took 10 mins to rise to correct temp. When he replaced stat with new one, the temp guage rose to correct temp in 5 mins   So if thermostat is not involved as much as you say, why the speedier rise in temp guage registering?
				Posted: Thu Apr 05, 2007 7:11 pm
				by francophile1947
				Old stat jammed open, therefore allowing flow through radiator??
				Posted: Thu Apr 05, 2007 7:12 pm
				Thank you Peter.  I still couldnt 'buy' the new theory, but was struggling to think of evidence to support my case.  You just did.  Balls in your court guys
				Posted: Thu Apr 05, 2007 7:13 pm
				by Jamesnjane
				some good points made there.  can anyone explain the little hole already in the thermostat does it remain closed on that ball thingy under pressure or does it let water through,  im starting to think maybe in japan there used less at a lesser speed so under less stress but come over here and get used alot more so maybe there not coping too well ( i know alot of bongo owners motors are running spot on mine did for a year) its just a thought, alot of cars in the past have been known for overheating problems so i cant help but think a couple of holes in the thermostat are just helping the old girl along!!  id love to solve the problem though
what does everyone else think??
				Posted: Thu Apr 05, 2007 7:18 pm
				by Peg leg Pete
				Also if the radiator only plays a small part in the cooling system as suggested, why is it so large and have two fans to assist cooling??
				Posted: Thu Apr 05, 2007 7:21 pm
				by francophile1947
				Jamesnjane wrote:some good points made there.  can anyone explain the little hole already in the thermostat does it remain closed on that ball thingy under pressure or does it let water through,  im starting to think maybe in japan there used less at a lesser speed so under less stress but come over here and get used alot more so maybe there not coping too well ( i know alot of bongo owners motors are running spot on mine did for a year) its just a thought, alot of cars in the past have been known for overheating problems so i cant help but think a couple of holes in the thermostat are just helping the old girl along!!  id love to solve the problem though
Could be a valid point - maybe, as Bongo not exported, system was designed for only 60mph.
				Posted: Thu Apr 05, 2007 7:23 pm
				by francophile1947
				peter humphrey wrote:Also if the radiator only plays a small part in the cooling system as suggested, why is it so large and have two fans to assist cooling??
In case it gets hot????
				Posted: Thu Apr 05, 2007 7:25 pm
				by Peg leg Pete
				still does not ring true - run less and at lower speeds, They would not have fitted such a large double fanned radiator.
				Posted: Thu Apr 05, 2007 7:26 pm
				by Peg leg Pete
				After all mazda skimped fitting spacesaver wheel
				Posted: Thu Apr 05, 2007 7:28 pm
				by francophile1947
				If the traffic in Japan is as bad as we are lead to believe, the Bongo could spend a long time stuck in traffic jams - a large radiator and fans are then essential because there is no airflow without the fans.
