Head or Gasket?
- Simon Jones
Re: Head or Gasket?
....hopefully the liquid in the bottle is red/orange coolant, or otherwise he's got a bit of a rust problem
Re: Head or Gasket?
Thats just the 50:50 antifreeze Mel (NOT rust Simonrita wrote:Hi,Dave what is in the bottleAethelric wrote:Thanks Mel, I'll give you a call.The Great Pretender wrote:I'm still not convinced that there is a head problem. The turbo has been mentioned before as a possible problem, as the pipework for it is at the stat housing fitting or removing the thermostat could affect air ingress. If a chat about it would help pm me your land line number.
In the meantime here are some pics
The old water pump
I think the rust stains have developed since I took it out
The bleed set up for single handed operation
Closer view
The old "Stat"
Now fitted.
I've used a half tank of diesel since I put it back together with the sawn off stat and the new pump with no problems, and I have a 200 mile round trip to do this weekend, so fingers crossed.
I've now done four tankfuls (diesel that is) with no problems other than a crap heater and higher fuel consumption since putting it back together.
- dandywarhol
Re: Head or Gasket?
A crap heater would indicate either air in the matrix or it's blocked. Are both heaters crap?
It's my belief that the rear heater matrix can be the cause/source of airlocks
Re: Head or Gasket?
Sounds similar to mine Steve. I traffic I find if I switch on th A/C it switches on the radiator fans so the engine stays cool. I don't know the crossover temperature, other than above 82C air gets into the system and at running temp with no stat (probably around 40C, if thats what you measured) its OK. Thanks for the info on the bolts.stevedon wrote:I should add with the thermostat out mine averaged 40 deg on a run but once stuck in traffic (there is some here in NZ)it chucked the water out at @80deg (ive got a TM2 fitted).
the head cannot be retorqued as it has an initial torque up of xxNm then 90deg then another 90 deg so there is no specific figure also they are stretch bolts and are designed to stretch,over tightening is not good
Dave
Re: Head or Gasket?
The heater is probably OK considering the coolant in it is only around 40C. With no stat fitted the coolant takes ages to get warm and it never gets hot, so the heaters are not exactly "fierce"dandywarhol wrote:A crap heater would indicate either air in the matrix or it's blocked. Are both heathers crap?
Dave
- mikexgough
Re: Head or Gasket?
I feel the same way Alan....dandywarhol wrote:A crap heater would indicate either air in the matrix or it's blocked. Are both heathers crap?
But that is my opinion and during the bleeding process I employed.....I made sure the rear heater was good an hot before turning attention to the warmth of the bottom hose....
- dandywarhol
Re: Head or Gasket?
Ah, forgotten the stat was out...........................Aethelric wrote:The heater is probably OK considering the coolant in it is only around 40C. With no stat fitted the coolant takes ages to get warm and it never gets hot, so the heaters are not exactly "fierce"dandywarhol wrote:A crap heater would indicate either air in the matrix or it's blocked. Are both heathers crap?
Dave
Auntie-Freda
Re: Head or Gasket?
Thats odd I noticed the opposite. ie rev engine level drops in bleed vessel. (or maybe my Bongo does have a stat fitted!!!!)Interestingly, with the stat fitted, reving the engine increased the pressure in the head relative to the header tank, and the coolant rose in the bleed vessel and dropped in the header. But with no stat it was the opposite way round. Revving the engine dropped the level in the bleed vessel. I think it may be due to increased flow through the head causing a venturi effect in the bleed pipe. Another datum for the cooling system data bank!
