Unfortunately the fuel additives may be better, but there's no check on storage conditions and it all comes from the same tanks at the depotmikexgough wrote: There was some crud in the tank....but a warning from BH.... they have filled new containers with diesel straight from reputable fuel companies pumps n(not supermarket) and had crap settle in the bottom of the containers.....so there is some dodgy fuel out there....
Grr.... not starting
Re: Grr.... not starting
- mikexgough
Exactly.... which is why with my symptoms I checked out the usual suspects first.... filters etcfrancophile1947 wrote:Unfortunately the fuel additives may be better, but there's no check on storage conditions and it all comes from the same tanks at the depotmikexgough wrote: There was some crud in the tank....but a warning from BH.... they have filled new containers with diesel straight from reputable fuel companies pumps n(not supermarket) and had crap settle in the bottom of the containers.....so there is some dodgy fuel out there....
Mind you the garage was concerned that the fact they cam timing was out and then the spanner monkey had tweaked the diesel pump, this was a contributing factor with the pump failure, but possible not an absolute cause....I did ask the veg oil question and was told if the quantities/ratio is okay then no problem...it was just shocking to see all that metallic swarf that was in my injectors....
Still at least I am almost maintenance free for a while..... new Cambelt and other drive belts done, and with a full stainless zorst and a K&N recently... just got to do the filters, tyres, bulbs and other regular consumables...when required, now where is the ignition key, I feel another drive is needed...
Great ending mike,Nice one bellhill!
They saved my bongo last year when both my bumpstops fell off...
- mikexgough
Well it was Bell Hill or Wheelquick to sort out my Diesel pump issue and Bell Hill was closer for me and suited my circumstances....bigdaddycain wrote:Great ending mike,Nice one bellhill!They saved my bongo last year when both my bumpstops fell off...
They did try everything before changing the pump, and with the difference the new cam belt, timing set up has made along with as new injectors....... I now wonder if some of the Bongos I have driven and travelled in need some attention...
Again... well done Bell Hill...
