Day meet- Scottish Borders?
- mister munkey
Re: Day meet- Scottish Borders?
Has the volcanic ash disabled all your cameras?
MountainGoat
No not quite Chris, just a cameraman who is a bit slow off the mark. Waiting, waiting, waiting.
Tony
Tony
I remembered to bring my camera.....but when I saw Alec with tripod and semi professional outfit...... I decided to leave it in the van. I tend to be very good at taking pictures that either chop off the heads, or make it look as if telegraph poles or trees are growing out of people or vans!!!mister munkey wrote:Has the volcanic ash disabled all your cameras?
It seamed it was very difficult to get all of us in one place at the same time. Tony was so obsessed with making best possible use of the 'free toilets' he didn't even notice the Tweed about 20meters away
- dandywarhol
Y'mean like this?dunslair wrote:dandywarhol wrote:Still in the Hebrides til Sunday night, maybe next time - new "toy" doing well
Hope the weather is holding out for you. I look forward to seeing the holiday photos posted when you feel good n ready![]()
You know what we're looking for...Idilic sandy white beaches with the van parked artfully in the middle distance
Looks like you been feeding your bongo steroids Dandy
What is it? certainly looks like you got a few feet more space in there, but it's not a bongo
Hope the van performed as well as expected..with no 'parking moments' to spoil the trip.
All the best
David.
ps. Did you watch your favourite....... Monty Hall last night? We missed him be a few days last summer....thankfully
- dandywarhol
Its a Toyota Hiace Hitop Superlong Custom
I shouldn't compare the Bongo with it - they're different animals - but it's difficult not to - so here goes.........................
Bongo drives better, less of a van
Hiace handles better - less affected by crosswinds, passing trucks etc. but ride is harsh with the rear leaf springs.
Bongo quicker off the mark, but is unconverted and nearly 1/2 a tonne lighter.
Hiace (surprisingly) quieter at cruising speed despite the engine in the same place and having a mechanical viscous fan
Bongo has more modern interior/switchgear etc. - Hiace designed in the 80s, a generation behind the Bongo
Hiace a much better campervan - full kitchen, cupboards, fridge, sink, extraction fan, portapotti, diesel powered heater all in the back, behind the centre seats which rock & roll to face front or rear. Lots more space despite being only 5 metres long.
Hiace has great, big, comfortable downstairs bed - and a drop down double bed which swings down from above the passenger/driver's area and extends to the rear - clever bit of kit, sleeps 4 if you're close friends!!
Hiace has selectable 2 or 4 wheel drive, limited slip rear diff, locking front hubs which manually disconnect the driveshafts/cv joints, front diff and front propshaft. If you know you aren't going on the slippy/rough stuff then you leave the hubs in "free" position and it drives like a 2WD with no power losses through the front transmission. If you're doing a combination of road/slippy stuff then you lock the front hubs manually at the wheels and set off in 2WD, when you need 4WD you just flick a switch and the whole transmission drives all wheels through a viscous coupling.To top that, there's also a low/high ratio option giving you 4 gears in low range 4WD to climb the steepest slopes - we tested it up tractor/sheep tracks in the Hebrides at Easter - pretty impressive climing abilities with Yokahama van tyres - although the cups and plates rattled a bit!!
The Hebridean trip was a good shakedown to see if we really liked it and it came out pretty well - but withdrawal systems from the Bongo could be the big problem....................
dandemann8
Here we have the shortened version I hired in Australia.
First class vehicle, wouldn't mind importing one of these as they are only built for the southern hemisphere
Bongo no more........... ;-(
- brorabongo
Hope your not planning to leave us Dandy.
Your new wagon, looks like it's more suitable for your camping needs, so can see why you've "changed".......that was close...I nearly said "upgraded."
Be strong, one day you might get over it.........others hav'nt.dandywarhol wrote: but withdrawal systems from the Bongo could be the big problem....................
All the best with your new mota.
Apologies for the delay in posting the pics folks....Here we go.... Reminds me of the line up from The Usual Suspects! Has anybody here actually seen Keyser Soze
steviebongo
- Tribal Elder
Usual suspects david? more like the fantastic four!
great pics from alec just as well as the kit he was using looked expensive (don't no much aboot camera's).Hope ure jar lids fit ok sum pics me thinks req'd
cheers stevie
cheers stevie
steviebongo wrote:Usual suspects david? more like the fantastic four!![]()
cheers stevie
I was keeping that one quiet untill I checked that it actually worked and they didn't all fly off at the first pothole
