dandemann8
Post
by dandemann8 » Fri Jun 04, 2010 10:01 pm
Bongo no more........... ;-(
Post
by mikeonb4c » Sat Jun 05, 2010 9:55 am
mister munkey wrote:I am indeed
The Luckiest Man Alive
Picked it up half an hour ago, drove three miles home & all seems well. Didn't need the head off, cost £120 to get sorted,
RESULT!!!!!
No time to post much right now as I'm packing up for a tiny test drive to Angelsey & late already.
Great news - every Bongo cloud has a silver lining
Hope the test drive goes OK
mikexgough
Post
by mikexgough » Sat Jun 05, 2010 7:12 pm
Nice outcome Chris....
helen&tony
Post
by helen&tony » Sun Jun 06, 2010 11:46 am
I have to add to that...I really am pleased for you...A nice cheap fix....and a smile from the Munkey Mascot...he'll be as chuffed as a chimp with 2 tails
Post
by francophile1947 » Sun Jun 06, 2010 11:58 am
helen&tony wrote: a chimp with 2 tails
Funny chimps in Bulgaria - Africa's don't even have one tail
friendeedebs
Post
by friendeedebs » Sun Jun 06, 2010 5:33 pm
Glad you got the bongo sorted and made it to Anglesey
Hope you got back ok too
Debs
mister munkey
Post
by mister munkey » Sun Jun 06, 2010 6:30 pm
Cheers gang. More often than not I find you guys to be a lot better than the Samaritans!
Dunno the techie talk but it was explained to me what went wrong, this is how I interpreted it . . .
There are 5 caps that hold the camshaft in place, each has a bearing inside - I think. On the front one, the bearing had failed leaving the camshaft to spin rather too freely & eventualy snap.
Chief Engineer timed it up & put it back together using parts from Maxs' old head, firing it up without the rocker cover to make sure oil was getting up where it should & noted that the oil feed to No 1 clynder takes 5 or 6 seconds longer to spurt out than the others - although once flowing the feed seems strong.
Advised to have a 15/20 second tickover at start up in the morning before wringing its neck up the road to give the oil a chance to circulate.
mister munkey on Sun Jun 06, 2010 7:38 pm, edited 1 time in total.
Post
by mikeonb4c » Sun Jun 06, 2010 7:08 pm
mister munkey wrote:Cheers gang. More often than not I find you guys to be a lot better than the Samaritans!
Advised to have a 15/20 second tickover at start up in the morning before ringing its neck up the road to give the oil a chance to circulate.
Great news MM - glad its sorted
Yorkshire Puddings
Post
by Yorkshire Puddings » Sun Jun 06, 2010 9:52 pm
Was good to see you could all make it on Friday also with Bongo .xx
helen&tony
Post
by helen&tony » Mon Jun 07, 2010 8:55 am
mister munkey
Post
by mister munkey » Sat Jun 11, 2016 3:53 pm
Bumping this in memory of the magnificent Max Headroom and yet another fine example of how you guys go to extreme lengths to help each other out.
It's sad to see you leave us Nic, you'll be deeply missed.
Post
by Bob » Sat Jun 11, 2016 5:29 pm
A fine Bongonaught.
