The Great Pretender wrote:Whatever you used to get those figures needs checking. As you know I had a thermistor in direct contact with the coolant located in the top hose, the temp was in the high 60's before any movement then quickly reached 11 o clock.haydn callow wrote:
What happens is !!!! The standard Bongo temp gauge is activated by a sensor which is located in the cylinder head......When the coolant in the cylinder head reaches 25C the gauge starts to move....when the coolant in the cylinder reaches 45C the gauge will be at it's "normal" 11 o'clock position.......it will then sit at that position untill the coolant in the cylinder head reaches "approx" 110C.....and you are on the cusp of a overheating event.....
O.K. Did a very careful recheck to-day.....My standard Bongo gauge moves off the COLD stop at 28/29C..........It reaches the "normal" 11 o'clock position at 40C........my sensor is positioned within the Top hose about 8inches from the Cylinder Head outlet.......this has been much the same on all 3 bongos.....the one at the moment is a 2.5 V6 but I would think the gauge sensors are all the same values.........I have used the i-alert to measure coolant temp and I have used 2 differant sensors ....both gave the same readings....The i-alerts seem to all give the same readings +/- 1C and when tested in a pan of water with a digital (infer red) temp gauge they are extreamly accurate.
