Interesting point about your temp gauge
				Dave Mason
It's possible that an identical unit will not perform so well in the next Bongo, but there is only one way to find out.
Paul9, if/when you give the OK on the first production unit and send the test unit back to me, I'll set that test unit up the same as your first production unit and supply it to the second Bongo customer. That way if it doesn't perform the same there are some immediate options to make adjustments with the switches inside the test unit and refine the design - slightly I'd hope. Then I'd swap the test unit for another production one as I've done for you.
I won't be building any quantity until it's clear that it's worth fitting the Mason alarm into a Bongo.
				paul9
				Dave Mason
				Grahame at work
				paul9
recieved second cable from dave now ,and still working on it,the one i have been testing seems fine on my bongo,but may give different results on other vehicles,just waiting to test on  my other bongo, probably tomorrow if it passes mot,then maybe know a little bit more.
ok fitted alarm to second bongo,will have to wait until tomorrow 19th to see if it performs the same as on my other bongo,no mot at moment but is booked in tomorrow,will update asap.
				paul9
i fitted the alarm to my other bongo and it performed the same way as when fitted to original bongo,dave mason has made a few more and they are on sale now via his link,they are being sold on a first come basis,so anyone want to try one out get in touch with dave.
very simple to fit and a very usefull addition.
http://www.townace.plus.com/ie/ietemga2.htm
				the janner vanner
				Grahame at work
				John the sparky
				paul9
you can mount it anywhere you like,i just have a stick on piece of velcro and mout near clocks,anywhere as long as you can get to it to adjust easily,once you find your setting you can place anywhere,even hidden behind dash,you get a beep when first switch ignition on and this lets you know its working,and sometimes when you switch indicator on you may get a beep
				John the sparky
				paul9
fit the cable first,you can attach alarm unit later,take a note of were the temp gauge normally sits at running temp and also at speed under a little strain like going up a steep incline,then fit alarm unit to cable and you will see the difference in gauge reading,don't be alarmed if gauge goes up more than before,this is quite normal after fitting alarm unit,then you can set the alarm to go off  when engine temp reaches or goes above normal temp,sounds confusing but its quite simple really,
