Loss of water from expansion tank - advice wanted
dandywarhol
Re: Loss of water from expansion tank - advice wanted
Post by dandywarhol » Mon Apr 14, 2008 11:45 pm
An air flap shuts off the heat from the matrix and simultanously another flap lets cold air into the interior in all the heater boxes I've seen - I don't see that a Bongo one is any different TGP.
I see what your saying about having the heater set to hot to moniter the bleeding though. But they aren't set to hot to allow coolant flow around.
Post by Simon Jones » Mon Apr 14, 2008 11:46 pm
Mike - yes have tried to bleed it as per manual, but if I ran it for 10 mins as per the instructions, I 'd have no water left in the system to bleed. I may try taking the glow plugs out tomorrow & turn it over on the starter. If there is any water in the bores, then it will blow out the holes. Trouble is, I can't work out whether the problem is in the top or bottom of the engine. Even if I took the head off again for another look, I don't think I'm going to see any signs of a problem - any water in the head will be disturbed by the removal, so will end up on the gasket / block.
Post by Ian » Mon Apr 14, 2008 11:50 pm
Have you tried the "Bell Hill" test?
The best way to prove the theory is by taking the vehicle on a 30 minute run and parking it up for the night. When the engine has cooled enough to work on, remove the glow plug rail and all 4 glow plugs from the cylinders. In the morning return to the vehicle and place a strip of card some 9” by 20” across the top of the glow plug holes and turn the engine over. In doing this the glow plug holes act as vents and anything in the cylinder will be forced up through them rather than down the valves. With any luck you will have 3 black carbon marks and a larger watery mark where water has collected in the cylinder overnight.
dandywarhol
Post by dandywarhol » Mon Apr 14, 2008 11:53 pm
Good one \:D/
The Great Pretender
Post by The Great Pretender » Tue Apr 15, 2008 12:07 am
Agree Dandy, the heaters always work before the cooling system does so as the demisters work first, and the heater.
To infinity and beyond
Aethelric
Post by Aethelric » Tue Apr 15, 2008 1:22 am
dandywarhol wrote:An air flap shuts off the heat from the matrix and simultanously another flap lets cold air into the interior in all the heater boxes I've seen - I don't see that a Bongo one is any different TGP.
I think this is the usual system in modern vehicles. It was not always so. Some of my older cars, which included a Triumph Herald (nice) and a Lada (crap) had taps in the water system. When you were used to them, and moved to a more modern vehicle what was striking was how fast the temperature of the air changed when you moved the heat control. It took ages for heater matrix to cool down. The Lada heater was phenomenal BTW. You could not bear it full on in January with the windows open.
Post by haydn callow » Tue Apr 15, 2008 11:29 am
does anyone know what the compression ratio of a diesel is compared to a petrol engine? being a compression ignition engine rather than spark ignition. I seem to remember it is much higher and I suppose this makes them more likely to fail long term.
Post by mikeonb4c » Tue Apr 15, 2008 12:26 pm
Simon Jones wrote:Mike - yes have tried to bleed it as per manual, but if I ran it for 10 mins as per the instructions, I 'd have no water left in the system to bleed. I may try taking the glow plugs out tomorrow & turn it over on the starter. If there is any water in the bores, then it will blow out the holes. Trouble is, I can't work out whether the problem is in the top or bottom of the engine. Even if I took the head off again for another look, I don't think I'm going to see any signs of a problem - any water in the head will be disturbed by the removal, so will end up on the gasket / block.
Oh bum, I feared that would be the reply, but had to check.
Ian's 'Bell Hill' suggestion sound excellent and worth a try.
Like Haydn, I do wonder if the high compression ratio (said to be higher than the standard Ranger engine?) , alloy head/iron block etc. make this an engine than be quite easily upset given a certain combination of events (but what?). Otherwise (as Harry reminded me at Stainforth) it is as tough as old boots (toughest engine he'd ever seen, to use his words). If only the designer would write his memoirs and give us the full story (in English!) :lol: :lol:
Aethelric
Post by Aethelric » Tue Apr 15, 2008 12:44 pm
haydn callow wrote:does anyone know what the compression ratio of a diesel is compared to a petrol engine? being a compression ignition engine rather than spark ignition. I seem to remember it is much higher and I suppose this makes them more likely to fail long term.
The compression ratio in a diesel engine is much higher, but its the pressure formed after ignition that forms the biggest pressure. In spark engines the fuel burns very quickly. If it detonates, i.e. all burns at once in an explosion then its know as "knocking" or "pinking". In deisels the fuel always detonates, which is why they are rougher, particularly at tickover. But they are designed to take the higher stresses and, like any engines good ones last a long time and poor ones don't.
Post by Simon Jones » Tue Apr 15, 2008 12:47 pm
I'm going to try to get it to a point where I can take it for a short drive & then I can try the Bell Hill suggestion. I fear that the pressure will build up & dump the water before I can get very far - that will leave me with a very dead Bongo.
I'm going to do some reading up the Ranger engine, but can anyone confirm they are different compression ratios? I understand that many manufacturers like Mercedes or VW tend to use the exact same engine, but the power is all down to differences in the ECU programming & possibly the performance of the turbo.
I can get hold of a chap who works for the commercial vehicle division of Ford, so he may also have some suggestions.
Peg leg Pete
Post by Peg leg Pete » Tue Apr 15, 2008 9:43 pm
When I had an airlock, the heaters ran cold :roll: once bled correctly, heaters behaved :wink:
Image Pete
Post by haydn callow » Tue Apr 15, 2008 10:40 pm
My friend in Oz has been following this post. He made the following comments...might be worth looking into.
I don't know if you have it in UK but we have a product called "Chemiweld"
I have used on engines with blown head gaskets and "mystery" leaks that the RACQ couldn't find with great success.
It is designed to seal cracks in cylinder heads and blocks.
I reckon if I were him I would give it a try as he has nothing to loose.
If it works the repair is permanent.
At least if he tries this and it fixes it it will give some indication of what the problem was.
I used it on the daughters car when she cooked it and warped the head.
She drove it for a year after until I fitted it with a new head.
Linda had a Ford Falcon which would suddenly loose coolant over night.
I pressure tested, tried everything.
The RACQ had a look as well, but could find nothing.
I Chemiwelded it and problem solved.
That was 10 years ago and the car is still running around Townsville with it's new owner of 4 years
The Great Pretender
Post by The Great Pretender » Tue Apr 15, 2008 10:53 pm
If my memory still works I think the Toyota Lucida web site have hade mixed results using "Chemiweld". I suppose it depends on what it needs to do to make things better.
Post by haydn callow » Tue Apr 15, 2008 10:54 pm
The Great Pretender
Post by The Great Pretender » Tue Apr 15, 2008 11:10 pm
Peg leg Pete wrote:When I had an airlock, the heaters ran cold :roll: once bled correctly, heaters behaved :wink:
Ve hav Vays of making you behav but making it bleed is drastic. :-" :-" :-"
