Thanks Haydn.haydn callow wrote:I've no idea why your observations should be different...I just know that the movement of the needle and the stat opening/closing are not related.
The needle reaches 11'o clock at about 55C and it does then NOT move until the coolant temp reaches around 110c........during this "dead needle" period the stat is doing its thing without affecting the needle at all........do the FREE gauge mod and you will see exactly when the stat opens/closes (as I suspect you can with the Mason fitted.
I'm just putting my views across and as they are in agreement with another respected member and are built on our observations and experience, I post them (even if they were wrong)
But there is a serious point here. I've seen something happen, and it does need explaining. Also (and the K series article is just one thing that appears to confirm this, with its discussion of dynamic effects) the rate at which hot water reaches the sensor (and thus the rate of change of signal to the temp gauge) is quite likely to be influenced by how cleanly and rapidly the stat. opens. The change from 10 mins to 5 mins is harder to explain unless perhaps, the stat for some reason of other is not closing fully. But it was still observed to happen and it would be good to have an explanation.
Please keep posting.
