If the 5 year coolant contained abrasive silicates, as many do, maybe that's why you "still" got sediment - the interaction with silicone hoses reported earlier in this thread. Some early silicated long life antifreeze mixtures were abrasive enough to also chew up aluminum engine components, presumably creating sediment in the process.Timnz wrote:I've been using Prestone 5 year long life coolant in mine for 4 years, 3 with silicone pipes and no problems to report, after 80,000km, but I still noticed sediment built up in the top of the radiator. probably best to go with cheap 2 year green glycol anti-freeze and flush/treat your system at every change..
I've just changed it and gone back to standard 2 year stuff.
Is it true that there are very few anti-freeze choices in NZ? One input I've had says only one type is available, with differentiation only by the same stuff being sold under different brand names. That input also said that it's all silicated and includes phosphate in the mix - no phosphates are any longer used here, due to environmentally negative connotation. Your input, however, shows that at least two types are available.
