Jaylee wrote:-
So, then... Why did they stick a ruddy gert air con condenser in front of it??
It's all about priority & how things work efficiently.
The air con. condensor works by cooling compressed refrigerant which has just come from a compressor as a hot high pressure gas.
It passes through the condenser & cools to a high pressure liqued.Heat has been removed to the surrounding air.
This high pressure liqued then passes through a very small hole into the evaporator.
Once in the evaporator the liqued pressure drops & it can now evaporate into a gas again.A liqued turns into a gas by attracting heat from the air around it.
This low pressure gas then returns to the compressor & the whole cycle begins again.
HEAT CAN ONLY BE TRANSFERRED TO A COOLER SUBSTANCE.(not shouting, just stating a bit point before continuing)
If you want your car interior at 10*C, then the low pressure air con gas has to be lower than this, to be able to absorb heat.
To be efficient the returning high pressure liqued needs to be as low a temperature as possible to be able to absorb as much Bongo interior excess heat as possible.
If the condenser was on the other side of the coolant radiator, on a hot day the minimum air temperature is going to be above 90*C (see previous post) after the air has cooled the engine coolant.This temperature is going to be unable to cool a high pressure air con. refigerant & so as the refigerant progresses through to the evaporator it isn't cold enough to be able to absorb any Bongo interior heat & the air con. would be ineffective.
With the condenser in front of the radiator, the ambient air temperature cools the air con. refigerant but the air temperature as it leaves the condenser is still less than 90*C and is therfore able to absorb heat from the coolant as it passes through the radiator.
This results in both systems losing excess heat to the air as efficiently as possible.
It would be great if the front of the Bongo was a bit taller or wider then both condenser & coolant radiator may be mounted side by side & could be cooled independantly, each with it own clean cool air source.
This may be a bit long winded but I hope it makes sence.
Nigel
