Over-revving and gear change problem
Owermoo
Post by Owermoo » Mon Mar 19, 2007 3:05 pm
I am having a problem with my Bongo over-revving and the gearbox seeming to kick back down to a lower gear when on hills. The weird thing is that when I had the cv boot replaced the problem was cured and it drove like a dream for about a month. Now the problem has returned and I am at loss to explain it. I have looked at stuff posted on the forum relating to similar problems but cannot see any that completely explain the problem I am having. Any ideas anyone?
dandywarhol
Post by dandywarhol » Mon Mar 19, 2007 3:41 pm
When was the fluid changed and the filter cleaned. It should be done every 24,000 miles .
Owermoo
Reply
Post by Owermoo » Mon Mar 19, 2007 4:07 pm
When i bought it from the dealer last year they said that the van had been serviced before it was shipped from Japan. I have nothing to say that the oil had been changed. Do you think that this may be the problem and if so why?
dandywarhol
Post by dandywarhol » Tue Mar 20, 2007 12:17 am
The oil gets a bit of a hard life and can breakdown in viscosity which can affect the pressure but more importantly the mesh filter screen is VERY fine and gets choked with black scum causing by the paper clutch plates wearing. If you've no evidence of an oil change I'd get it done - worked wonders for mine. :)
Owermoo
Thanks for the info
Post by Owermoo » Tue Mar 20, 2007 10:37 am
Thanks for the reply and info - I'll give the oil change a go. Is it an easy job to do myself or do you recommend taking it to a dealer? Cheers
dandywarhol
Post by dandywarhol » Tue Mar 20, 2007 3:57 pm
If you've got the facility to get the van up high enough to remove the pan and an oil disposal system and a parts washer to clean the filter then you could do it yourself.
also...........there's no drain screw on the pan so it takes a bit of fiddling about with the bolts to allow the pan to drop a corner to drain the old oil off......................................
Second thoughts - get a garage to do it.................. :?
Owermoo
Post by Owermoo » Tue Mar 20, 2007 4:07 pm
Thanks again for the info - I think I will go for the garage option!
Post by bigdaddycain » Tue Mar 20, 2007 10:22 pm
Aren't the gaskets hard to get hold of too dandy? I seem to recall reading that a new gasket has to be cut out from cork sheet or something?
I imagine that the flange of the pan would need to be pressed onto the sheet forming a template, from which a replacement could be cut.
jimsmimm
Post by jimsmimm » Tue Mar 20, 2007 11:16 pm
had mine done recently by local mechanic who did my 4x4s before the bongo ,he'd never seen a bongo before but never found any problems in doing it and never required a new gasket.....
dandywarhol
Post by dandywarhol » Wed Mar 21, 2007 12:21 am
I carefully eased the pan off and the gasket was ok and doesn't leak :)
Post by bigdaddycain » Wed Mar 21, 2007 12:31 am
Excellent!... Thats on the to do before the MOT service then...Along with new cambelt,EGR blanking,oil change,fuel filter,... ooh, i,d best start saving :shock:
Post by francophile1947 » Wed Mar 21, 2007 12:36 am
dandywarhol wrote:When was the fluid changed and the filter cleaned. It should be done every 24,000 miles .
Hi Dandy
Is there any way of knowing if it needs changing? I'm not having any problems but I don't know when mine was done. When I checked the level, the fluid was a nice clean, clear red.
wrster
Post by wrster » Wed Mar 21, 2007 2:15 am
Out of interest, mine didn't have a gasket fitted - straight metal to metal faces. Seals fine...
Also, I bought one of these which is used far more than I thought it would be: Pela 6000 oil extractor. With the rear right wheel up a bit, I sucked the auto fluid out leaving less than an egg cup full in the sump. Which made working under the Bongo a bit easier.
Also use it when changing the engine oil - I suck out 4lt before dropping the sump plug in the usual way; 3lt in a drain pan is easier to carry about than 7...
Post by mikeonb4c » Wed Mar 21, 2007 9:30 am
Ooooh I like that very much indeed, and I could probably collect it. Gotta stop spending though - damn :evil:
