Glow Plug wiring mod
Posted: Wed Mar 28, 2007 2:37 pm
by francophile1947
Just done Ben Bruce's wiring mod to the glow plug relay - really easy job and it works!! :D :D
Just remember to leave them on until you pull away, cos' it stalled when I turned them straight off after starting the engine :oops: :oops:
Posted: Wed Mar 28, 2007 2:46 pm
by shutty747
could you point me to this intriguing sounding mod please?!
Posted: Wed Mar 28, 2007 3:02 pm
by francophile1947
It's in the Fact Sheets in the Member's Area - at the bottom of the Glow Plug sheet.
The hardest part was finding the purple wire cos' it's hidden by the plastic covering. It comes out of the back relay, which is covered by what looks like a stiff clear plastic bag.
Posted: Wed Mar 28, 2007 4:06 pm
by haydn callow
YEP !! I did mine about 4 weeks ago. Dead easy and seems worthwhile.
Posted: Wed Mar 28, 2007 4:35 pm
by brorabongo
Got all the parts/wire for doing the job, now just waiting for my holidays :D
After just changing the plugs I thought I would do this mod to help them last! This sounds like it could save me a small fortune. Must be worth more in the than the membership alone! well worth joining!!!!!
(Any commission available?) :lol:
Posted: Wed Mar 28, 2007 8:52 pm
by dandywarhol
Did mine last year and used a switch with a bulb in it - just shows you how LONG the plugs can stay on for on a cold day............MINUTES! :shock:
Posted: Fri Mar 30, 2007 12:14 am
by dandywarhol
Well, today was a cold, driech, harr misty morning so I thought I'd check how long the glowplugs stay on. Caught up in slow moving traffic and using very little throttle so the plugs didn't kick out with turbo boost...................................5 MINUTES later they finally turned off just as I got onto a dual carriageway - exactly the same time as the gearbox took lockup (same sensor circuit, although this was the first time I'd proved it :lol: ).................no wonder cheap ones don't last long :shock:
Posted: Fri Mar 30, 2007 12:22 am
by francophile1947
Coo Dandy - I bet you're glad you did that mod, even good plugs aren't really designed to work that long.
