Page 1 of 2
				EEK- MY BONGO SCARED ME
				Posted: Tue May 01, 2007 7:57 pm
				by biobits
				Hi Guys,
Please help - i have had a problem.
This afternoon  I was driving around the streets with no problems. I pulled over and parked at the side of the street. then when i pulled off something odd happened.  I had no power - my foot was on the floor but i was still just crawling along. Took ages to speed up at all and i had to drive with my hazards on - it was so slow - and i  did hear a few strange noises.
I managed to get to my husbands work and turned the engine off - called my hubby and he came out and turned the bongo back on and drove off  like normal - no problems
Can anyone suggest what may have happened please?
				Posted: Tue May 01, 2007 8:03 pm
				by brorabongo
				Where there any warning lights lit on the dash?
				Posted: Tue May 01, 2007 8:05 pm
				by dandywarhol
				Did you forget to let off the handbrake by any chance...................
				Posted: Tue May 01, 2007 8:07 pm
				by waycar8
				did you notice any smoke from the back?
i had same problem a while ago..............never found out what had happend, but its never done it again.
i think the the glow plugs didnt fire up properly.
				Posted: Tue May 01, 2007 8:10 pm
				by brorabongo
				dandywarhol wrote:Did you forget to let off the handbrake by any chance...................
I was going to ask that but I thought I would be more subtle
				by biobits
				no warning lights and no i did not have the hand brake on - there was just no power - it was as if it could not get out of 1st gear but it was not revving high even with my foot to the floor.
it was not overheating either
it was very strange.
				Posted: Tue May 01, 2007 8:17 pm
				by dandywarhol
				brorabongo wrote:dandywarhol wrote:Did you forget to let off the handbrake by any chance...................
Sorry.......I should have asked
"Is there perhaps a slightest possibility the preferred parking brake and auxilliary retardation device could have inadvertantly been applied by unforseen forces or a family pet?"
				Posted: Tue May 01, 2007 8:19 pm
				by waycar8
				lmfao @ DANDY
				Posted: Tue May 01, 2007 8:22 pm
				by biobits
				no matter how you put it  - i definitely did not leave the handbrake on
you lot are really daft - subtlety  not necessary but it is amusing -
				Posted: Tue May 01, 2007 8:28 pm
				by brorabongo
				Nice one Dandy.
Just an idea-
Could it be possible, that it was the throttle cable sticking? has anyone heard of this in Bongos before?
				Posted: Tue May 01, 2007 8:35 pm
				by papa joe
				Handbrake off ......Was it started up then ???
I feel another locked messge coming !!
				auto
				Posted: Tue May 01, 2007 9:18 pm
				by Bollicky
				sticky solenoid maybe
				Posted: Tue May 01, 2007 9:27 pm
				...and you are quite sure you didnt put it into S1 or L1 (or whatever its called) instead of D when moving the gear selector?
				Posted: Tue May 01, 2007 9:35 pm
				by jimsmimm
				May have been some dirt in the fuel strainer  causing fuel starvation which has cleared its self .... could be worth while getting it out and giving it a clean  with some cotton buds.... had similiar problems before myself though not as bad as yours sounds,( bongo wont pick up properly and struggles to rev past 2000 RPM, really bad on hills)...  I reckon my tank has some rust on the inside and have now fitted an inline filter in the fuel line up stream of the fuel strainer to catch anything before it reaches the mesh  which is very small and fine and easily blocked.......its been discussed before on the forum and there's pictures posted somewhere ...try running a search
fuel strainer....
				Posted: Tue May 01, 2007 10:37 pm
				by biobits
				thanks for all the suggestions
I know it was in d as i tried putting it in the other gears to see if it would help
....,( bongo wont pick up properly and struggles to rev past 2000 RPM, really bad on hills0
  this is exactly what it was like - but my hubby says we already have the extra filter
i hope it will not happen again,
