				elevating roof micro switch,
				Posted: Sat May 05, 2007 8:06 pm
				by Tom Cruise
				Hi one of the roof closure warning micro switches has gone on our bongo so the dash board roof closure light is on all the time. I can not see how to get the old one out, the wires are too short to just pull out and connect a new one.
Any ideas?
				Posted: Sat May 05, 2007 10:25 pm
				I'm interested in this one TC as my Bongo has had its flashing light on from when I bought it . Intend to fix it some time but - despite advice on BF - I haven't got my head around which which is faulty and causes the warning light to stay on.  People have said to me just get a microswitch from Maplins, but not being good at all that stuff I wouldn't know what to order or how to fit it!!!  I'll watc this thread with interest and god luck.
Mike
				Posted: Sun May 06, 2007 9:47 am
				by moonshine
				I would imagine it's the one on the nearside that operates the light.  My light hasn't worked since I bought the Bongo, but I suspect that's a blown bulb.
Some while ago I raised the roof to check it out, and when I lowered it again the beeper wouldn't stop.  That turned out to be the offside microswitch.  As a "temporary" repair (to shut it up!) I disconnected the wires to the microswitch and joined them together with an insulated joint.  I really will get round to replacing the microswitch one day, honest.
Now the bad news.
  The nearside microswitch is much harder to get at as the wiring is completely hidden.  I couldn't see how to get at that one without removing the roof!
				Re: elevating roof micro switch,
				Posted: Sun May 06, 2007 10:17 am
				by Tom Cruise
				Mine is also the nearside front switch. I think there are actually four on the roof? I did get it working for a short while with wd40 but that no longer works.
				Posted: Sun May 06, 2007 1:22 pm
				by moonshine
				There are two more (at least) microswitches further back, but I think these relate to the actual closing of the roof.  I think they operate when the roof is partially closed, so that you have to press the close button again to lower it the last bit.
				Posted: Sun May 06, 2007 11:46 pm
				I read somewhere on BF about sticking a bit of fag packet somewhere in order to stop the flashing.  Must investigate it sometime (a la moonshine - I'll do it.....manana)
