Anyone know if these work, why should we need it? what is the rush?
http://www.speedydelivery.co.uk/car-tun ... ongo.shtml
power boost?
Tom Cruise
- Bongonaut
power boost?
My other cars a Bongo!
ParkerNorris
- Bongonaut
Hmmm
The fact that they talk about changing ignition timing, in concert with the following from their FAQ section:
Q. Will this fit on my particular cars model ?
A. If your cars is equipped with electronic fuel injection, it will. 99% of cars manufactured after in or after 1988 are equipped with a fuel injection. It will however not work on turbocharged vehicles.
Leads me to think that it only applies to the petrol engined models.
Paul & Lara
It's 'Our' Bongo; not his, not hers...
I wouldn't touch this gizmo with yours!
As far as i can gather this little device will effectively bung in extra fuel (Like the engine is still cold)even when the engine is hot.
Essentially the motor will be running a very rich mixture,which, i suspect, will actually decrease the available power, when up to normal running temperature.
Overfueling is not a good thing on any engine,diesels are no exception.
- westonwarrior
