Helppppp please...!
I'm stuck....sat in bongo with everything apart and the dials just won't turn unless I do it mile by mile from the end. I may have to go and get a new clock from scrap but I'll have to remove the chip...uh....may need to move this to technical....
km to mph-h.e.l.p......
tattoodaisy
- Bongonaut
spe llink d*ue to Kirsty's sloe Brndy!
tattoodaisy
- Bongonaut
- westonwarrior
Ok if you are trying to change the odometer to read miles rather than kms because you have installed a chip
get a small screwdriver and insert it between the dials and prise them apart slightly and hold them apart with the driver, the dial should then turn freelyjust move along the row untilyou have set all dials.
I think the needle pulls off and reattaches afterwards
do you have a refaced speedo at the moment?
tattoodaisy
- Bongonaut
- westonwarrior
tattoodaisy
- Bongonaut
tattoodaisy
- Bongonaut
