Front Heater resistor
stueyboy
Folks, this might be a stupid question but need your help.
My fan is not working. I reckon it's the resistor pack that is gone as the fan works when connected to the battery and the fuse is fine.
So can someone please confirm what the resistor pack connections should look like please?
There is the black portion which the electrical block plugs into and the ali bit. Should the electrical connections (five of them) be soldered to the tabs coming out of the ali bit as none of them are connected at present. Basically, is the resistor component in the black bit or the ali bit because if it is the latter then there are no connections to it at all at present.
That's why I am confused as I wouldn't have expected all of the soldered joints to break or is that something that can happen. It certainly would explain why the fan isn't working.
Ta
Stu
Ta
Stu
Re: Front Heater resistor
This FAQ should point you at all the info you need - http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727
stueyboy
Thanks for that. I think I have found the answer in other posts so apologies for repeating the past. Sounds like the de-soldering is pretty commonplace by the looks of it.
No problem, it's one of the most commons faults, now make sure the fan isn't starting to bind, the resistors have gone for a reason
stueyboy
yep, the fan is currently exploded into its component parts on my workbench. Some nasty gung resident in the housing, so I might drill a hole in it once it is lubed up. Also will check the drain hole under the windshield as that seems to be an issue as well.
Hi stueyboy...I keep an old cable tie in the battery tray for de-gunking the drainhole.
stueyboy
Too late!!missfixit70 wrote:Good luck putting it all back together without the springs disappearing off across the workshop
It's times like those that you wish you kept things tidier
stueyboy
Quick update. Cleaned the fan motor and then soldered all the connection on the resistor and we have a working fan again. Thanks for the help. I did source a replacement resistor from fleabay for £10 in case my repairs didn't work so I now have a spare.
Nice one, did mine 18 months ago, although the fan resistor was ok as I remember, still going strong.
Have you noticed it's any more powerful than before it went kaput? Mine certainly blasted out much better on top speed
rabbitsquasher
ahh this could be useful... my fan at full pelt is soooo quiet I wasnt sure it worked! Then it does take half an hour to demist the windscreen
Should be blasting at you, sounds like it's time to waste a few hours under the bonnet
rabbitsquasher
as if i havent got enuff to do!
stueyboy
Funny you should mention that, it is a bit of a blast on full power. When things go gradually like that, you don't notice until it's fixed.missfixit70 wrote:Nice one, did mine 18 months ago, although the fan resistor was ok as I remember, still going strong.
