Advice needed please.
Sometimes my ABS light on the dashboard comes on whilst driving.
I stop,turn off the ignition,restart,light goes out,does'nt happen again for several days.
Brake fluid is fresh and to the recommended level,pumping the brake pedal does'nt do anything,just ignition off then back on again.
It's a V6 rear wheel drive,opinions welcome
ABS Dashboard Light
ABS Dashboard Light
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
Re: ABS Dashboard Light
Anybody.!!!
Try n clean the sensor that where i would start, funny enough my mate has same prob on his quatro lately turned out to be the pick up point on the hub or summit like that diff car i know
Dar
Dar
PS I'd be lying if i said i knew what i was talking about, but i usually discover when i got things in bits my mates a mechanic so he points me in the right direction usually he refuses to work on it says do it meself and he will bail me when i get stuck good fun tho
- dandywarhol
There'll be a sensor going down to each brake corner - usually a simple electromagnet.
Disconnect the sensor wires at a multiplug and use an ohmeter to check for resistance/open circuit at each sensor. Its normally a break somewhere.
Thanks Cheffy & Dandy,
Thought that might be the problem(sensor),looks like i shall have to start crawling about underneath again.
Why oh why does it nearly always involve down and under ,i am not getting any younger y'know
It should be in front of you while sat in the driving seat
Thanks again to the both of you
Dolly1 when lanp blinking is error in system. You need read this code (codes) for understanding problem.
Reading codes for ABS:
1) with ABS lamp:
http://mikrob.ru/download/file.php?id=42704.jpg
2) with voltmeter:
http://mikrob.ru/download/file.php?id=42705.jpg
read you codes and write here, i try to explaine
1) with ABS lamp:
2) with voltmeter:
Russian Mazda Friendee Club
http://www.mazdafriendee.ru
Hi DemonAV,
Those two diagrams are most helpful
Thank you very much.
Lionel
Lionel
