Page 1 of 2
Flashing roof warning light
Posted: Wed Apr 22, 2009 9:18 pm
by daveblueozzie
As the title says i have a flashing roof warning light on the dash.
When i started the bongo up today, the flashing warning light came on and also the beeps, lifted the roof up then closed it, the beeps stop but not the flashing warning light. thought it might have been a one off, but it seems to do all the time. i did raise the roof last weekend (Saturday) and sprayed some silicon grease onto the runners but i did use the bongo afterwards and also on Sunday without any bother, so apart from taking the bulb out to stop it flashing do you guys and gals have any ideas as to why it suddenly started to flash.
Re: Flahing roof warning light
Posted: Wed Apr 22, 2009 9:32 pm
by ScubaBongo
I have the same fault.
Well, almost- mine sometimes beeps/flashes when I start the engine. so i slighty open the roof, close again, and BOTH the beeps and the light stop.
seems more likely to occour when I haven't driven for a few days. Prob 1 trip in 3 or 4 starts like this.
Sorry, no solution, but a problem shared and all that!
Got to be a sensor or more likely micro-switch fault?
Posted: Wed Apr 22, 2009 10:17 pm
Mine has been flashing ever since I bought it
Keep meaning to do something about it but hey........
Welcome to the League of Honourable Ageing Flashers Dave
Posted: Thu Apr 23, 2009 8:59 pm
by Bongo Boozer
Heres my answer from last year and still working to this day
"I sorted mine out today with the help of a friend (fork lift truck engineer)
Open the roof slighty about 2 foot (its easier to reach the micro switchs)
put a bit of cardboard between the switch contacts. if this stops the bleeping do what i did next
unscrew the black part of the microswitch only slightly put a screw driver behind and lever (very gently not too much) towards the cream coloured plastic part that the metal strip touches and re tighten.
Then do the same to the cream part (2 screws on these) and lever towards the black part and re tighten.
Do this to both sides (I only had to do the front to cure my bleeping) and test.
Mine works how it should now (no bleeping when it's down correctly).
The idea is basically to get the 2 parts closer together."
Cheers Steve
Posted: Fri Apr 24, 2009 2:21 am
by bigdaddycain
I wonder if one of the micro switches has become contaminated due to the recent runner greasing? Maybe they just need a wipe?
Posted: Fri Apr 24, 2009 12:33 pm
by missfixit70
Squirt of contact cleaner mebe?
Posted: Fri Apr 24, 2009 1:24 pm
I think the switch unit on mine is completely stuffed - no possibility of a quick fix
Posted: Fri Apr 24, 2009 11:08 pm
by You've Been Bongod
TAKE THE BULB OUT OF THE DASH
THAT WILL CURE IT
Re: Flashing roof warning light
Posted: Sat Apr 25, 2009 9:21 pm
by aitch
Posted: Sun Apr 26, 2009 11:55 am
You've Been Bongod wrote:TAKE THE BULB OUT OF THE DASH
THAT WILL CURE IT
I know I know. I'll get a Round Tuit
Posted: Sun Apr 26, 2009 11:58 am
by missfixit70
mikeonb4c wrote:You've Been Bongod wrote:TAKE THE BULB OUT OF THE DASH
THAT WILL CURE IT
A small black one to stick over the bulb?
Posted: Sun Apr 26, 2009 10:22 pm
by Mike Jill and Emily
Mine has always flashed like this - I think it is the front microswitch on the passenger side that is the miscreant. I tried lube and I also tried bending the lever a little - this worked for a while but then went back to flashing. I have tried to remove the switch, but our Japanese friends have left the wires so short that it won't budge.
So I figure if I hear the locks engage after the roof is fully down the warning light can happily be a disco light
If anyone finds an easy way to change the stupid switch without taking half the roof to bits I may re-visit a reapir
Posted: Sun Apr 26, 2009 10:29 pm
by daveblueozzie
The flashing light i can put up with, but not the beeps, they only stop when i lift the roof then lower it again.
not had chance to sort it out yet, i disconnected the battery, this does not work, but it was worth a try just in case.
Posted: Sun Apr 26, 2009 10:35 pm
by lizard
I hope that this can be solved as it may take a contagious to find out what he problem is.
Posted: Sun Apr 26, 2009 10:55 pm
missfixit70 wrote:mikeonb4c wrote:You've Been Bongod wrote:TAKE THE BULB OUT OF THE DASH
THAT WILL CURE IT
Not far off. Actually, I have a square of insulating tape on the instrument console cover and that all but obscures it - you can tell I'm Irish.
My experience/approach is exactly the same as Mike Jill and Emily's. I can see (hear?) if would be a different matter if the beeper kept going like DBO's
