Bleeding your Bongo
Lickhill Manor, Stourport on Severn 17 to 22 June
Moderator: Ian
Re: Bleeding your Bongo
Post by haydn callow » Sat Jun 13, 2009 8:41 am
Alan of Alan's showed me this method ...if it's good enough for Alan then it's good enough for me.
Bulwell Bongoleers
Post by Bulwell Bongoleers » Sat Jun 13, 2009 12:31 pm
Hi Haydn,
Not sure if i'll be there in time for fri's demo, so could you put me down for sat?
Thanks Andy
Manda & Andy
Post by mikeonb4c » Sat Jun 13, 2009 1:02 pm
I wasn't lucky enough to have anyone like Alan nearby to show me how they did it, so I had to rely on the Mazda Bongo workshop manual instructions. They worked fine for me (I'd have been disappointed if they hadn't!). For those in my situation and who can't get to Haydn's demo, the workshop manual says:
Once you have drained the system and tightened the radiator drain plug
10. Set the air bleed hose downward as shown in the diagram [hooked over steering wheel]
11. Set down a container for draining coolant
12. Remove the [radiator] filler cap
13. Fill the coolant to the upper surface of the radiator
14. Attach the filler cap
15. Fill the coolant to the radiator reservoir tank flange surface
Caution
* Remove the reservoir tank cap to bleed air
* A/C Switch should be turned off
16.Start the engine and idle for approximately 10 minutes to warm up
Caution
If any of the following phenomena occurs, stop the engine to lower the water temperature as filling is incomplete. After water temperature is lowered, repeat steps from (15)
(1) Water temperature rises too high
(2) Cooling fan operates
(3) Steam comes out constantly from the air bleed hose
17. Perform the following operations after the engine is warmed up
(1) Keep the engine running at 2500rpm for 6 minutes
Warning
When checking the lower radiator hose (radiator side), be aware of burns or getting caught in the cooling fan.
(2) Check the lower radiator hose (radiator side) is warm. If it is cold, keep the engine running at 2500rpm for 3 minutes, then check again if the radiator hose is warm.
(3) Fill with coolant up to the radiator reservoir tank flange surface
Warning
When attaching the air bleed hose plug, the air bleed hose should be facing upwards as it could cause a burn if it leaks on you
(4) Attach the air bleed hose plug as shown in the diagram
(5) Attach the reservoir tank cap
(6) Keep the engine running at 25000rpm for 5 minutes
(7) Keep the engine idling for 3 minutes
(8) Keep the engine running at 25000rpm for 5 seconds then return to idling status. Repeat this 4 to 5 times.
18. Stop the engine and check the coolant level after coolant temperature has lowered.
Post by haydn callow » Sat Jun 13, 2009 6:17 pm
Mi...I thought you were attending the bash "over in the nettle patch"
thedogsbollox
Post by thedogsbollox » Sat Jun 13, 2009 10:06 pm
mikeonb4c wrote:I wasn't lucky enough to have anyone like Alan nearby to show me how they did it, so I had to rely on the Mazda Bongo workshop manual instructions. They worked fine for me (I'd have been disappointed if they hadn't!). For those in my situation and who can't get to Haydn's demo, the workshop manual says:
Caution
Caution
Warning
Warning
I'm in trouble, My Bongo won't do 25000 revs #-o
B*Witched Blingo
Post by B*Witched Blingo » Sat Jun 13, 2009 10:15 pm
Why? Don't they all. Am I being female here? #-o
You Tube Films Click Here
thedogsbollox
Post by thedogsbollox » Sat Jun 13, 2009 10:17 pm
B*Witched Blingo wrote:I'm in trouble, My Bongo won't do 25000 revs
Simply put YES
They go up to about 5 or 6 thousand, not 25 thousand.
Post by mikeonb4c » Sat Jun 13, 2009 10:47 pm
Simply put YES
If you can't yours up to 25000 then 2500 will do :lol:
mrs_muffinhead
Post by mrs_muffinhead » Mon Jun 15, 2009 10:31 am
Please can you put me down for Saturday's session.
Many Thanks,
Kathryn
Silver 99 New Shape, 2l Petrol Bongo
Triple/R
Post by Triple/R » Mon Jun 15, 2009 11:59 am
Hi Haydn--could you put me down for Friday at noon please--& if you remember I'm after a coolant alarm but not sure which model--- fitted as well please.
Regards Ray.
Regards Ray & Christine
Return to “Bongo Bash 2009”
