Tyre pressure
Posted: Fri Jul 03, 2009 10:13 am
by Mack
Am I being thick (as usual!), but I can't find the recommended tyre pressure for van in my handbook. Just want to know what it should be fully loaded. Anyone?
Re: Tyre pressure
Posted: Fri Jul 03, 2009 12:04 pm
by francophile1947
On a plate inside the passenger door frame (or driver's - can't remember which
Re: Tyre pressure
Posted: Fri Jul 03, 2009 1:16 pm
by scanner
francophile1947 wrote:On a plate inside the passenger door frame (or driver's - can't remember which
Driver's - but that's for Japanese tyres under Japanese conditions and I seem to recall that most people haven't found that suits the UK on UK tyres.
And it's in something like sushi per sq/yen.
PS don't ask me why I'm just passing on what I've read on here.
PPS I tend to use about 36psi all round with 215/60-16s if that helps.
Re: Tyre pressure
Posted: Tue Oct 20, 2009 12:08 am
by Konni
According to my handbook, for a 2WD diesel unconverted, it is 180kPa front, and 240kPa rear, or 26PSI front and 35PSI rear in English
Re: Tyre pressure
Posted: Tue Oct 20, 2009 12:13 am
by missfixit70
Which is usually way too low, as posted on here repeatedly. Usually closer to 38 - 40 psi (obviously check the recommended maximum on your tyres)
Re: Tyre pressure
Posted: Tue Oct 20, 2009 11:35 am
by haydn callow
I run at 40psi all round....I belive I get a couple more MPG...since I pumped them up from 34F/36R...Seems to handle better as well
Re: Tyre pressure
Posted: Tue Oct 20, 2009 1:45 pm
by davelou
I agree totally with hayden, been running mine at 40psi for 3 years.Dave
Re: Tyre pressure
Posted: Tue Oct 20, 2009 5:03 pm
by technophobe
YUP! Agree. But suggest 40psi front and 45psi rear, but check how the tread fits on the road. Tyres will last longer
Re: Tyre pressure
Posted: Tue Oct 20, 2009 5:09 pm
by mister munkey
Agreed.
Although I'm on 18s, running around 38 on the front caused this unbelievably quickly.
It passed an MOT like that but that expensive rubber is fairly well shot & looks shabby.
Now try & keep to 40/45.
Re: Tyre pressure
Posted: Tue Oct 20, 2009 5:11 pm
by haydn callow
MM.that on both fronts ??
Re: Tyre pressure
Posted: Tue Oct 20, 2009 5:14 pm
by mister munkey
Yep.
Re: Tyre pressure
Posted: Tue Oct 20, 2009 5:48 pm
by scanner
Have you had your tracking checked? - if it was just tyre pressure that wear would be on both sides.
Re: Tyre pressure
Posted: Tue Oct 20, 2009 6:02 pm
by mister munkey
Not the best picture I guess but just nipped out & checked Scanner, insides are scrubbed too.
Re: Tyre pressure
Posted: Tue Oct 20, 2009 6:41 pm
by scanner
mister munkey wrote:Not the best picture I guess but just nipped out & checked Scanner, insides are scrubbed too.
It doesn't look to be anywhere as bad though.
It could be worth getting the tracking checked - there isn't usually any charge unless they need to adjust it.
Re: Tyre pressure
Posted: Tue Oct 20, 2009 6:42 pm
by mister munkey
I'll do that.
Cheers.
