HELP - MY ROOF WONT CLOSE !!!!!!
Posted: Sun Aug 09, 2009 2:45 pm
by alibabi
Anyone got any ideas how to close my electric top roof, both fuses 10 and 12 are ok, funny thing is the warning light and roof alarm sounder initiates when the handbrake is off but when you pull the brake on the warning light and sounder stop.The handbrake switch appears to be working as you would expect. however in either position the roof will not go down.
regards
Re: HELP - MY ROOF WONT CLOSE !!!!!!
Posted: Sun Aug 09, 2009 3:28 pm
by daveblueozzie
handbrake on and in P for park.
Posted: Sun Aug 09, 2009 4:59 pm
by Bulwell Bongoleers
have you pressed the "lock Cancel button in the roof"?
http://www.youtube.com/watch?v=dRcbbH_zTF8
the above link will show you where it is
Andy
Posted: Sun Aug 09, 2009 5:32 pm
by alibabi
Many thanks, roof is now closed!!!
I have operated roof many times without using this switch but now I know what its for.
Posted: Sun Aug 09, 2009 6:52 pm
by francophile1947
alibabi wrote:I have operated roof many times without using this switch but now I know what its for.
:? :? I guess your roof was never properly up then :?
Posted: Sun Aug 09, 2009 7:00 pm
by maxheadroom
francophile1947 wrote: :? :? I guess your roof was never properly up then :?
I guess it's an age related thing, ah sorry you said roof :lol: :lol: :lol:
Posted: Sun Aug 09, 2009 10:31 pm
by missfixit70
If the roof doesn't go fully up & stop beeping - it's not locked out & fully up, therefore you won't have to use the lock cancel button, as Franco says, sounds like it's the first time you've had a full erection :wink: If it doesn't stop beeping, lower a few inches & raise it again, usually sorts it, make sure the hatch is open & you aren't creating a vacuum as it lifts. Sometimes the roof tent gets a bit stiff & crumpled, holding the roof back, unzipping it can help to get it to lock out but sometimes a little helping hand is needed to push it up into the locked position.
As long as the handbrake is on, the gear it's in shouldn't matter - I just tried it on mine to check :wink:
Posted: Sun Aug 09, 2009 10:35 pm
by mister munkey
Top tip from Chell & Ady that cured mine is a liberal squirt of Spry Crisp & Dry on the hydraulic rams.
Sweet as a nut now.
=D>
Posted: Mon Aug 10, 2009 10:33 pm
by Marcus Beechcroft
Glad it's been solved so easily - looked in the Handbook and the procedure to overide the locking mechanism, using a toogle rope [supplied when new?] looks a bit of a nightmare!
Posted: Mon Aug 10, 2009 10:40 pm
by missfixit70
There's usually an easier solution [-o<
Posted: Mon Aug 10, 2009 10:43 pm
by daveblueozzie
missfixit70 wrote:If the roof doesn't go fully up & stop beeping - it's not locked out & fully up, therefore you won't have to use the lock cancel button, as Franco says, sounds like it's the first time you've had a full erection :wink: If it doesn't stop beeping, lower a few inches & raise it again, usually sorts it, make sure the hatch is open & you aren't creating a vacuum as it lifts. Sometimes the roof tent gets a bit stiff & crumpled, holding the roof back, unzipping it can help to get it to lock out but sometimes a little helping hand is needed to push it up into the locked position.
Must admit never left it in any other gear apart from P when parked.
Posted: Mon Aug 10, 2009 10:48 pm
by missfixit70
Likewise, but thought I'd check out of curiosity :wink:
