No heating and temp gauge on H
Posted: Wed Dec 16, 2009 11:52 am
by Benson
Hi All.
Started Bongo this morning left to tick over while i scraped the ice, got in and no heat from blower
Drove about a mile down road and gauge went straight to HOT, stopped and left it there. Hope I have not done any damage
Waiting for recovery to take me to garage to thaw out and put in new antifreze.
Fingers crossed
Re: No heating and temp gauge on H
Posted: Wed Dec 16, 2009 11:57 am
by bigdaddycain
Hi Benson... It sounds like you are low on coolant, (cold heaters are often a preemptive warning of this, especially with the notoriously slow bongo temp gauge) Chances are you've sprung a leak on one of the myriad of coolant hoses,hopefully no lasting damage has been done
Make sure the garage you get recovered to are au fait with bleeding a bongo! Best of luck...
Posted: Wed Dec 16, 2009 12:17 pm
by stilldesperate
If they have any doubt on bleeding the system, don't forget the members area is free to enter now, the fact sheet might be useful to them.
Good luck.
SD
Posted: Wed Dec 16, 2009 12:30 pm
by apole
Hi there,
With luck no damage will have been caused but it's important now to be sure that the root cause of this is identified and fixed, good time to check all the hoses etc to be sure they are in good condition, flush and refill the system. Be sure it's bled properly and personally I'd get a low coolant alarm fitted asap, probably at the same time whilst it's being worked on.
You did the right thing to stop and leave it, was it making any boiling kettle type noises etc?
Andy
Posted: Wed Dec 16, 2009 1:01 pm
by miker
Could this also be a failed waterpump? no circulation but coolant getting hot
Posted: Wed Dec 16, 2009 1:09 pm
by bigdaddycain
Possibly Miker...No mention By Benson as to the level of the coolant .
