Page 1 of 2
Main Rear Door light passenger side
Posted: Mon Jan 25, 2010 11:51 am
by Huw
- yr 2000 2.0ltr petrol Bongo.
Hi there, i need to replace the bulb in this light, the main white rear light on the rear door. I've taken the back interior panel off, and removed the nuts on the side of the light. How do i get the light off? do i remove the plastic sheeting on the interior to access the requisite bolt/screw? if so how do i remove it? is it replaceable? thanks! again
Re: Main Rear Door light passenger side
Posted: Wed Jan 27, 2010 5:12 pm
by Huw
hi, can anyone help?? thanks
Posted: Wed Jan 27, 2010 6:30 pm
Which light are you reffering to this one ?
If so then you just squeeze the clear plastic front, end to end, and it will pop off (this picture doesn't have the cover on at all as the lamp has been replaced with LED's), the trouble is the 4 little plastic lugs also have a habit of snapping if your too rough with it :( You can see where the lugs fit in the picture two little slots at the left and right sides above and below the fixing screws. The bulb is a small festoon type.
Posted: Sun Jan 31, 2010 11:38 am
by Huw
hi there, the external light, the large white/clear light situated on the outside of the rear door, passenger side
Posted: Sun Jan 31, 2010 2:35 pm
by missfixit70
Are you sure it's not a retrofit thing? doesn't sound standard to me. Can you put a pic up?
Posted: Mon Feb 01, 2010 12:24 pm
by jaybeeonline
Methinks it may be the reversing light bulb.
J.
Posted: Mon Feb 01, 2010 12:46 pm
by jaylee
jaybeeonline wrote:Methinks it may be the reversing light bulb.
J.
Jaybee, me thinks you could be right!?? :idea: :?: :?: :wink: :D
But is the reverse light in the tailgate?? I fancy from the pic, the reverse light might share with the indicator, on the clear lower part of the main tail cluster?? Just above the reflector.
The clear bits on the actual tailgate is just window dressing!
In which case, removal should be like the old shapes..!
J>
Posted: Mon Feb 01, 2010 1:27 pm
by apole
Hi there,
If it is this then the reversing light would have been retrofitted in the bodywork cluster, unlikely to be in the lamps on the tailgate itelf as the white units here have no bulb holder installed.
If it is this, then you open the tailgate, remove teh 2 screws in the side of the lamp unit and push outwards to release the entire unit. Probably the same as the non facelift.
Andy
Posted: Mon Feb 01, 2010 1:28 pm
by jaybeeonline
J>
You may actually be right - I never noticed the indicator and reverse lights like that before #-o
J
Posted: Mon Feb 01, 2010 1:31 pm
by missfixit70
apole wrote:Hi there,
Andy
Are you getting confused with the fog light Andy? The clear lenses on the bodywork (not sure about the tailgate, I thought they were just reflectors) were fitted as reverse lights from the factory.
Posted: Mon Feb 01, 2010 2:15 pm
by apole
Hi Kirsty.
Mine is a facelift and unless it's different my reversing light is in the outer clusters and not in the tailgate.
The clear lamps in the tailgate have no light holders in them at all. Some of the red ones do and they are tail lights. Don't have the car with me to double check how many of the red ones have holders and bulbs in.
Hope this helps and hope I'm not confused as I'm getting old now !!!
My foglamp was installed in the offside reversing light cluster to replace a reversing lamp, looks like a new cable has been run from a switch in the dash.
This is why I wanted to upgrade my reversing lights as I only had the one nearside bulb which was like a glow worm.
Posted: Sat Feb 06, 2010 2:07 pm
by Huw
sorry chaps!! its not the large clear on its the large red light on the tail gate, passenger side! i'm dumb, sorry about that
Posted: Sun Feb 07, 2010 6:24 pm
by Huw
I've removed the nuts from the side of the tailgate, and removed the inside panel, i looks like there are more nuts to undo to get the lights off? under the plastic water shield? it just seems like a lot of work to change a bulb!!
Posted: Sun Feb 07, 2010 6:44 pm
by missfixit70
Does this help? http://www.lushprojects.com/bongopartsm ... 1of03.html May be worth dropping Bigdaddycain a pm as he's had a fair bit of messing about fitting a new shape back end on an old shape, so should be able to help.
Posted: Thu Feb 11, 2010 2:07 am
by Huw
Yeah i've got that, looks like i'll have to remove the inner panel and water shield then! cheers and thanks again
