Shredded rear tyre
Posted: Tue Mar 16, 2010 12:45 pm
Driving to work early this morning, in a wee bit of a hurry, and something definitely didn't feel right.
I thought I could hear a diff whine, then I thought it sounded like a wheel bearing.
Then it got very rapidly worse. Lots of noise, vibration, etc.
Pulled over sharpish, and found the nearside rear tyre in shreds. Tread is intact, outer sidewall is split almost all the way round. Inner sidewall isn't too happy either.
Thank god I got a proper spare!!
Swapped in 5 mins, and managed to get to the check-in for the flight I was heading for in time (with about 2 minutes to spare!)
Quick inspection revealed no damage to the tread, no screws, nails, etc.
I suspect that the pressure has been dropping but due to the 98 rated sidewalls I've not noticed it looking flat. And due to my own stupid fault I've not been checking the pressure. And I have a pressure gauge in the driver's door pocket too. No excuse really.
So, if you have all been good girls and boys and fitted decent high load rated tyres, make sure you check the pressure properly rather than "looks OK from here"
At least I have 2 weeks offshore to sort out a replacement for the day I come home.
