mason alarm
Posted: Mon Mar 22, 2010 8:54 pm
by You've Been Bongod
hi all what temp should a mason alarm show on the temp gauge when on a run??
this one sits at about 12 oclock and fluctuates up and down
thanks for any advice
Re: mason alarm
Posted: Mon Mar 22, 2010 8:59 pm
by missfixit70
sounds like it's doing it's job ok then, I'm sure a v6er will be along to confirm.
Re: mason alarm
Posted: Mon Mar 22, 2010 9:01 pm
sorry kirsty this is on my diesel bongo
Re: mason alarm
Posted: Mon Mar 22, 2010 9:04 pm
by missfixit70
Spot on then :wink: Mine hovers around vertical, I can get it to go up to about 3/4 of the way from vertical to the end of the scale while stationary, then the fans kick in & bring it straight back down in about 15 seconds, alarms set to start bipping about hafway between vertical & end of scale.
Re: mason alarm
Posted: Mon Mar 22, 2010 9:10 pm
by dobby
Ditto Carl
Worst is 1 o/c and set at about 4.5
Re: mason alarm
Posted: Mon Mar 22, 2010 9:29 pm
by heatherpetch
ours is 1 o/ clock or a tad more if towing and set about 4.5
Re: mason alarm
Posted: Mon Mar 22, 2010 9:47 pm
by mikexgough
that's the norm..... as Kirsty says....mid range and then when it creeps up..... fans in down she comes.....
Mine doesn't creep up as far as some but I have a new radiator..... mines the "default" 4
Re: mason alarm
Posted: Tue Mar 23, 2010 12:45 am
by missfixit70
This is the fan kick in point on mine
