Temperature gauge
Debs and David
Temperature gauge
Post by Debs and David » Sun Apr 11, 2010 6:06 pm
The needle of the temp. gauge hardly moves and never goes out of the white box next to the C, and it seems the faster you go the needle goes back towards it's rest position, i.e.70. Any thoughts, the header tank is normal and the engine isn't hot, is this the normal position for the needle?
David
Debs & David
You Need Degas to Make De Van Gogh
maxheadroom
Re: Temperature gauge
Post by maxheadroom » Sun Apr 11, 2010 6:07 pm
no thermostat?
Keep the Faith
mister munkey
Post by mister munkey » Sun Apr 11, 2010 6:10 pm
Nope. Not normal at all. The standard set up temp guage is pretty vague to say the least but they tend to sit around the 11 o'clock mark most of the time. Sounds like something ain't connected up right.
An expert will be along shortly with words of wisdom no doubt.
Debs and David
Post by Debs and David » Sun Apr 11, 2010 6:12 pm
maxheadroom wrote:no thermostat?
What difference would it make without one?
Debs & David
maxheadroom
Post by maxheadroom » Sun Apr 11, 2010 6:19 pm
it will run cool on the move. Do the heaters work?
Keep the Faith
Debs and David
Post by Debs and David » Sun Apr 11, 2010 6:22 pm
Yeah the heaters work ok.
Debs & David
maxheadroom
Post by maxheadroom » Sun Apr 11, 2010 6:26 pm
if the heaters are ok it may well be the gauge. PM me as I have a spare gauge you can have :D
Keep the Faith
