how long with pELA
Posted: Tue Apr 20, 2010 3:59 pm
by ronhud
I'm draining the engine oil with my new Pela. It's been going for about 30 mins and removed just over 4 litres. I keep giving it a few extra pumps every 7/8 min. Should it be taking this long?
Ron
Re: how long with pELA
Posted: Tue Apr 20, 2010 4:02 pm
ronhud wrote:I'm draining the engine oil with my new Pela. It's been going for about 30 mins and removed just over 4 litres. I keep giving it a few extra pumps every 7/8 min. Should it be taking this long?
Ron
Should be quicker than that if engine oil is warm. But it needs repumping more often than 7-8 mins I think as the vacuum decays to zero as oil is sucked up and it happens (on mine) much quicker than that.
My view overall though is I don't care if it takes a while becuase it is not requiring my attention anyway except for re-pumping every few mins (you can tell from the 'feel' whether the vacuum is exhausted). Don't pump more than instructions though (25 strokes?) as you don't want to overload it.
Posted: Tue Apr 20, 2010 4:04 pm
by francophile1947
As Mike says, it sounds like your oil isn't hot enough - mine didn't take that long
Posted: Tue Apr 20, 2010 4:39 pm
by ronhud
Thanks fror replies - it was hot when I started...! I noticed that I had not removed the filler cap and wondered if that had any bearing on it - need air in to push out so to speak so I removed that and going a bit quicker but not much. Maybe the oil has become thick. As Mike mentioned I will pump it more often.
Ron
Posted: Tue Apr 20, 2010 4:47 pm
ronhud wrote:Thanks fror replies - it was hot when I started...! I noticed that I had not removed the filler cap and wondered if that had any bearing on it - need air in to push out so to speak so I removed that and going a bit quicker but not much. Maybe the oil has become thick. As Mike mentioned I will pump it more often.
Ron
I suspect that is why its (appeared) to take so long
Posted: Tue Apr 27, 2010 8:17 pm
by missfixit70
Just did mine after a run in it. Only took about 5-10 minutes to drain with it warm & that included putting 0.5litre of clean oil in to flush & suck that out too. You can hear it pouring in & slowing down, then just keep pumping every minute or so.
Leave the suction tube attached to the container when it's done & clip it up so it drains anything left in the tube back into the container.
Oil change done in about 15 minutes, no mess no fuss
Posted: Sat May 01, 2010 8:26 am
by ronhud
Thanks Mis Fixit for confirmation of the normal time - how often/mileage do you change?
Ron
Posted: Sat May 01, 2010 10:10 am
by Muzorewa
Just done mine for the 25th time since we got the Bongo just over 2 years ago - that's 25 oil changes and 13 filter changes
Oil every 5,000km, filter every 10,000km as it says in the book. I know modern oils can last a lot longer but do you want to be taking short-cuts with your motor?
Posted: Sat May 01, 2010 10:39 am
by ronhud
Crumbs - are you doing 35000 miles per year?
Ron
Posted: Sat May 01, 2010 10:58 am
ronhud wrote:Crumbs - are you doing 35000 miles per year?
Ron
For those who doubt that the Bongo is capable of being a sturdy reliable high mileage beast, all I can say is:
Regular exercise is good for you
Posted: Sat May 01, 2010 12:52 pm
by missfixit70
ronhud wrote:Thanks Mis Fixit for confirmation of the normal time - how often/mileage do you change?
Ron
Every 6 months or 5000 miles (using 5w 30 semi synth, happy to lengthen the mileage a bit),
Muzorewa wrote:Just done mine for the 25th time since we got the Bongo just over 2 years ago - that's 25 oil changes and 13 filter changes
That's what it's about guys, using it as it should be
