Leisure Battery Flat / Radio? / Willinton Kit
Posted: Wed Apr 21, 2010 12:58 pm
I recently installed a willinton split relay kit along with a new bosch 110 leisure battery. Kit seems to be installed ok, relay works as it should and 2 wires were patched into the fuse box for lights/12v and radio. The fuses from the 2 additional wires for blinds have been removed.
LB should have been fully charged after a 2 hour drive, but a week later when I tried the radio the power was low(kept going on & off ater 5 seconds) and the 12v socket green light at the back was very dim, so something is draining the battery.
I suspect the radio (its a sony and I do remove the face) may be drawing current from my lb to retain its memory, but I would have not expected it to draw such a current. I have also read on other posts something about a radio feed going the the ignition - can anyone ellaborate?
Additionally................
Anyone got any advice as to how I can check my radio current? (I do have a voltmeter)
Any other ideas as to why the LB would drain?
thanks
thanks
