problem no 3 in 3 weeks :) eratic rpm/engine managment light
Posted: Fri Apr 23, 2010 7:36 am
Hi,really appreciate the advice I've been getting so far. next issue:
On start up this morning i noticed the glowplug light stayed on for 3 seconds after start up then went off. Which i thought was odd.
driving along i noticed the RPM was eratic 2cm either way of its usual position.
10mins into drive when doin 60mph it droped into a very low gear and the glow plug light came on for 2seconds and went off. the gears then changed back to normal.
It then started doing this more and more frequently until i got to work..
When i got out i thought i could smell burning clutch but that could also be my paranoia!
I have just had the fuel injection pump changed by auto diesel place from a used bongo which was working fine before been taken off. Reason had it changed because there was air getting into the last pump and couldn't find out where from. It would then stall. this problem has been fixed now though.
So any ideas from the pro's about what this next issue is??
I have it booked into garage AGAIN on Saturday to get a new exhaust mainfold fitted as it's blowing!
Only owned the bongo 3 weeks and love the car - starting to think a bad purchase tho now
tom
tom
