Cruise control and Temp gauge correction
Posted: Thu Apr 29, 2010 8:12 pm
by BONGODADDY
:D Evening all,
(No it's not the cops :lol: ).
Probably been asked a few times but could anyone give me the deatils of the best crusie control systems to go for for the Bongo ,maybe make and model numbers and where to get hold of them? and also i know that there was a mention of how to make the temp gauge accurate by soldering etc, has anyone got the info please.
Thanks for your time.
Re: Cruise control and Temp gauge correction
Posted: Thu Apr 29, 2010 8:15 pm
by missfixit70
PDF link for temp gauge mod - http://www.enginesaver.com.au/Tempgauge.pdf this can also be found in the factsheet on coolant alarms in the members area.
do a search on "cruise and control" it'll come up with what you want - the search function is your friend :wink: A lot of us have gone for the waeco MS-50, but there are other options.
Posted: Thu Apr 29, 2010 8:19 pm
by Doone
And here are a couple of 'search' results to get you started. :)
CRUISE CONTROL
MORE CRUISE CONTROL
Posted: Thu Apr 29, 2010 8:25 pm
by BONGODADDY
=D> Thanks Both,
I did look for the temp gauge factsheet but couldn't find it (I was looking for temp gauge factsheet #-o )
Once again a swift response, great help and much appreciated, i will see using the links which cruise control looks the best for the job although i reckon they all do what they say on the tin.
Let's hope for a dry Bank Hols 8)
Paul.
Posted: Thu Apr 29, 2010 10:08 pm
by Bob
I've got the MS50. Very pleased with it, and pretty simple to fit with Simon's Fact Sheet (and a little help here :wink: ).
I'm not sure it's still available though. :?:
Posted: Thu Apr 29, 2010 10:12 pm
by BONGODADDY
:D Thanks Bob, Good to know that there are positive reveiws from Bongo owners, Simons factsheet will help greatly and i have seen the system is still available to purchase.
Thanks for your reply.
Paul.
Posted: Thu Apr 29, 2010 11:13 pm
by munroman
I too used Simons excellent instructions for the MS 50.
I tested it on a long stretch of Dual Carriageway, I set it exactly for 60mph by the satnav, and after 29 miles the average speed had been 59.6mph, so very accurate, as well as giving the right leg a break.
I use it a lot in average speed camera areas and speed limited urban areas, much more than I thought I would before I had it.
Posted: Thu Apr 29, 2010 11:47 pm
by David Edwards
Yep got the ms 50 too, if you can find one now they are rare these days, very good as long as you remember they do not acknowledge roundabouts or junctions etc, lol, they just keep going at whatever speed it is set to, even it that is into a river,lol.
Posted: Fri Apr 30, 2010 12:46 am
by scanner
If they are still available here
http://www.edirectory.co.uk/gmtv/mib/d/ ... /10876515/
That is the best price and certainly the lowest P&P by far, you will find anywhere.
P&P from the usual suppliers in Germany is much more than that.
Posted: Fri Apr 30, 2010 11:57 pm
by The Great Pretender
IMHO............. :roll: :roll: :lol: ......Cruise control is the best mod for an automatic Bongo. I fitted an Audiovox CCS100 when the £ was worth something against the $, the MS 50 looks probably the best buy now with exchange rates. :wink:
