Page 1 of 2
air horns
Posted: Tue May 04, 2010 10:03 am
by bobngo
my horns were on there last legs ,so i bought and fitted some small air horns, now my friend tells me they are illegal .
after all that work ????
now these are not the big lorry type , which sit on the roof etc (truck on baby etc)
and they are not the sort that play tunes.( stupid kid on the block )
so if they are illegal why are they still selling them ???
can someone please clarify the situation
Re: air horns
Posted: Tue May 04, 2010 10:10 am
by Doone
The MOT legal guidelines for the horn are
ON THIS LINK
Re: air horns
Posted: Tue May 04, 2010 11:16 am
by jaylee
"A vehicle is allowed to be fitted with a bell, gong or siren, but not two-tone, only as part of an anti-theft device."
Mmmm.. I like this idea...!
http://www.youtube.com/watch?v=KLnyUZbJmOk
Re: air horns
Posted: Tue May 04, 2010 12:00 pm
by helen&tony
You mustn't have a horn which wakes the driver in front up, nor makes a loud noise, from the look of it!!!!
So...what's a horn for....????...I have a switch-over device....so that my exceedingly loud compressor horns actually DO warn....and I'm on the hunt for a nice set of train horns at a good price.....loudness may be illegal, but it has saved my bacon once!
Re: air horns
Posted: Tue May 04, 2010 12:46 pm
by loftustowncrier
If both horns play the same note that's not two-tone. My friend has air horns fitted to his motorbikes and they're legal.
Re: air horns
Posted: Tue May 04, 2010 2:08 pm
by Colin H F
Correct me if I am wrong but the way I interpretate it is if they both sound at the same time its ok, not one after the other. the reason I say this is my original jap horns ( that I swapped for my current air type horns ) were also two tone but one relay meant they both sounded together. Kirsty will no doubt join in on this post as she has changed hers. Colin
Re: air horns
Posted: Tue May 04, 2010 4:00 pm
by francophile1947
I've got triple air horns and they are perfectly legal, as long as they all blow together i.e one note only
Re: air horns
Posted: Tue May 04, 2010 4:11 pm
by Doone
That's right, one note (tone) is OK, 2 are not. We have dixie air horns on ours in addition to the standard horn. The standard horn keeps us legal for the MOT and the air horns operate off a seperate switch, just for fun.
Re: air horns update
Posted: Tue May 04, 2010 7:34 pm
by bobngo
mine operate together, but the actual horns are different lengths, to form two different tones ,so its actually two tones but running together to form a single note .
i think what the law means is that they must not operate alternatly, and so sound like an emergency vehicle.
anyway ,having fitted them ,i thought well give them a try just to see how much louder they are than the standard ones,
gave it a two second bust wow ,loud, very load,
then tried again ,went for one second ,then nothing , think i,ve blown a fuse , now the problem starts, where is the fuse ,and what amp rating is it , lush diagrams are not much good to me as they just confuse me.
so can someone please say , under the bonnet RH side , pink box, 50amp or where ever and what ever the fuse is .
(yes i know the box is not pink ,or 50 amp, just trying to give example )
please
Re: air horns
Posted: Tue May 04, 2010 8:04 pm
by francophile1947
There's a fact sheet here
http://www.igmaynard.co.uk/bongo/member ... usebox.pdf - fusebox is by driver's right knee.
Re: air horns
Posted: Tue May 04, 2010 8:11 pm
by bobngo
many thanks francophile thats exactly what i wanted and how i wanted it ,then i can understand better.
Re: air horns
Posted: Tue May 04, 2010 8:22 pm
by jaylee
Mine are not air horns, but they are two tone & play together... No problems with the MOT.. But that's cuz it's a diminished third.. The interval produced by flattening a minor third by a chromatic semitone in equal temperament it is enharmonic with the major second.. I think??
Re: air horns
Posted: Tue May 04, 2010 8:37 pm
by hembramacho
jaylee wrote:Mine are not air horns, but they are two tone & play together... No problems with the MOT.. But that's cuz it's a diminished third.. The interval produced by flattening a minor third by a chromatic semitone in equal temperament it is enharmonic with the major second.. I think??
That is correct.
Are there actual variances therefore in intervals used for horns (air, not French!). If so, I would go for a perfect 4th myself, or a major sixth as an alternative. Can anyone who has already fitted some comment on what interval theirs play at all?
Andrew
Re: air horns
Posted: Tue May 04, 2010 9:38 pm
by bobngo
what medicine are you two on , or what are you drinking ????
or which planet did you come from ????
Re: air horns
Posted: Tue May 04, 2010 9:47 pm
by bobngo
ok francophile sorted me out on the fuse, but now i find that each horn has an individual power supply, so is this two separate circuits, or two relays , or what ????
on this one even a lush circuite diagramm would be good
can anyone help, i,ve got to get this sorted.
i do,nt care if its in beethovens 7th in b flat minor played on a banjo as long as i get it working??
