rear heater pipework
Posted: Mon May 17, 2010 8:08 pm
by PeterP
The small bore metal cooling pipework to the rear heater - its located underneath the van and approx behind the drivers seat is very rusty.
Does anyone know where I can get replacements from and also what they are called?
Re: rear cooling/heating pipework
Posted: Mon May 17, 2010 9:23 pm
by missfixit70
Is it 61-2d1 on here? http://www.lushprojects.com/bongopartsm ... mgno=.html
Drivers side heater pipe part no S09A6122YA pretty sure bongo bits , ava, bellhill, JAS will be able to supply usually around £50
Posted: Mon May 17, 2010 9:35 pm
by dreamwarrioruk
i got one from bongobits last week, they are a pain to remove as there is one bolt hidden under the air intake pipe and then you have to circumnavigate all the pipes to get the damm old one out and the new in, judging by the state of mine i took off it was about to pinhole at anytime.
Posted: Mon May 17, 2010 10:03 pm
by PeterP
not sure on the part number, didnt think it was that big, I'll have another crawl under the Bongo tomorrow and let you know.
Yep, thats the one - 61-2d1
Posted: Mon May 17, 2010 10:06 pm
by dreamwarrioruk
that is the correct pipe if its the one from the rear heater matrix, it runs all the way into the bonnet area approx 5' long in length.
Posted: Mon May 17, 2010 10:07 pm
by missfixit70
If it's the one that goes across the back of the engine, it's this one, 61-301 http://www.lushprojects.com/bongopartsm ... mgno=.html part no S09A61226A
Posted: Tue May 18, 2010 12:05 pm
by PeterP
