V6 Oil Leak
Posted: Wed May 19, 2010 9:21 am
by BongoBonkers
Whilst changing the oil recently I have noticed a small oil leak on our V6. It seems to be coming from the area above the alternator. Does anyone know what the unit is directly above the alternator and whether it's a common source of leaks? It is belt driven.
Any other V6'ers got a similar problem? It's not enough of an oil leak to drop the level or even mark the drive or I would've noticed it before - hence one of my options is to look the other way and ignore it - but I'd like to sort it if I can as the engine's always been nice and clean.
Cheers, Dave
Re: V6 Oil Leak
Posted: Wed May 19, 2010 9:26 am
by You've Been Bongod
i will check mine and see when i get 5 but it sounds like the rocker gasket in which case 90% of bongos have a small amount of oil around that
i will report back
Re: V6 Oil Leak
Posted: Wed May 19, 2010 12:17 pm
by missfixit70
You've Been Bongod wrote:i will check mine and see when i get 5 but it sounds like the rocker gasket in which case 90% of bongos have a small amount of oil around thati will report back
Pretty sure that only really applies to diesels?
The leak isn't the camshaft seal is it? common issue with the V6.
Re: V6 Oil Leak
Posted: Wed May 19, 2010 2:40 pm
I haven't heard of a leak from that area, and my own looks fine there. We do have a suspected leak from the Cam shaft seals and several others seem to have that problem, very small amounts but it runs down the front of the engine and then back along the engine until it drips on the hot exhaust and causes a nasty hot oil smell. Next time I have the seat up I'll have a check and take some more photo's as well. the photo below was back in Nov 2008 (Click for fullscale image);
Re: V6 Oil Leak
Posted: Wed May 19, 2010 5:46 pm
by manners
I get a small drop of oil forming where the arrow is and it eventually drips onto the alternator think its the rocker gasket.
Re: V6 Oil Leak
Posted: Wed May 19, 2010 6:05 pm
by Ian
You might want to look at causes rather than symptoms, see this thread:
http://www.igmaynard.co.uk/bongo/forum/ ... 6&start=30
The garage have had mine for 9 weeks now and still can't resolve the leak.
Re: V6 Oil Leak
Posted: Wed May 19, 2010 7:22 pm
by Allans
There is a power steering pump in that area, which can leak.
On the V6, an oil leak from the camshaft seals / front crank oil seal is not uncommon. I've seen several of these. Oil leaks can cause other problems.
Keep in mind the oil can leak onto the cambelt.
It can find it's way past the power steering pump/bracket, down to the alternator. If too much oil drips into the alternator, it will also fail.
Re: V6 Oil Leak
Posted: Wed May 19, 2010 7:28 pm
by missfixit70
As well as make the cam belt fail if it's covered in oil.
Re: V6 Oil Leak
Posted: Wed May 19, 2010 7:35 pm
by Allans
You do need to keep an eye on oil leaks.
