Post
by missfixit70 » Wed May 26, 2010 8:50 pm
Worth checking the fuses under the bonnet, the fuse list is in the members area, I think it's separate fuses for front & rear heater fan, so you may be lucky & it's just a fuse, but chances are it's the usual, fan's got wet, bearing is getting tight or siezed & done the resistor packs, factsheets for the fan motor & resistor packs are in the members area too, usually fixable.
