coolant temperature question
Posted: Fri May 28, 2010 5:29 pm
just a quick question to put my mind at rest.
I'm new to these Bongo thingies but so far I like it
I had to put a new head on it and it has been bled and run and doesn't overheat.
So, my temperature gauge shows 3/4 of the way around to the red when it is running at 85-88 degrees, I know this as I have a temperature probe placed in the bleed hose as close to the engine as it can go which is linked to my digital stat which is calibrated to 100 degrees for work.
So what is Hot, as the system is pressurised I am assuming that it is above 100 degrees?
The radiator fan seems to cut in just above 90.
Also, when should the engine bay fan come on?
many thanks
Rob
many thanks
Rob
