Scavanger fan and central locking
Posted: Tue Jun 08, 2010 8:47 pm
by quinnw
Strange one... Unlocked Bongo, drivers side, the central locking didn't open the other doors. Turned engine on, flashing scavenger fan light (the orange coil). Coincidence? Or any ideas?
Re: Scavanger fan and central locking
Posted: Tue Jun 08, 2010 8:56 pm
by missfixit70
Check your fuses, top left or right, can't remember which, or it could be low battery.
Posted: Tue Jun 08, 2010 10:31 pm
by hembramacho
Have you got a leisure battery. If so, could be disconnected, or as Kirsty says low on charge.
Andrew
Posted: Sat Jun 19, 2010 5:37 pm
by quinnw
All fuses checked none blown.
Disconnected leisure battery, no change. Very crusty white deposit on negative terminal (not sure if this is relevant or red herring).
Any ideas?
Thanks.
Posted: Sat Jun 19, 2010 8:13 pm
by bobngo
white crusty bits ,if any, are normally on the positive terminal ,the +,
suggest you disconnect both terminals, (negative - first )
clean both terminals and connectors with emery paper
coat both terminals and connectors with vaselene
reconnect terminals to battery ,( positive +, first then negative- last)
note connecting/disconnecting terminals is always reversed when connecting /disconnecting ,
Posted: Sun Jun 20, 2010 3:04 pm
by quinnw
Cheers for the tip on how to disconnect battery...
Tried that. Cleaned it down and vaselined up. Fault still there.
Could it be the pre-heat sticking? If so how to fix that?
Thanks for all the help.
Posted: Tue Jul 13, 2010 1:45 pm
by Sluggy
I am having the exact same problem, started this morning, central locking not working and the coil light is flashing at me
any luck with yours quinnw?
Posted: Tue Jul 13, 2010 2:43 pm
by missfixit70
Sluggy wrote:I am having the exact same problem, started this morning, central locking not working and the coil light is flashing at me
If CL isn't working, I'd check battery voltage? or supply fuses, especially if you've got a LB fitted?
Posted: Tue Jul 13, 2010 3:25 pm
by Sluggy
sorted it
was just a wire from my willinton leisure battery kit, it had come loose from the no.1 fuse slot in the dash.
Posted: Tue Jul 13, 2010 3:53 pm
by missfixit70
Nice one, easy fixes are always good
