Fog light switch
Posted: Wed Jun 09, 2010 9:35 pm
by Dean
My Bongo came with a crappy aftermaket fog light switch. I've just bought a proper one but have no idea what the 4 terminals are used in what order.
Has anyone got any idea?
Dean
Re: Fog light switch
Posted: Wed Jun 09, 2010 10:06 pm
by jaylee
Dean wrote:My Bongo came with a crappy aftermaket fog light switch. I've just bought a proper one but have no idea what the 4 terminals are used in what order.
Dean
There are a couple of different types...
Like one o these..?
Or the one in the middle here?
Posted: Wed Jun 09, 2010 10:25 pm
by Dean
it's like the centre one in the bottom photo
Posted: Wed Jun 09, 2010 10:31 pm
by jaylee
Dean wrote:it's like the centre one in the bottom photo
OK..? Did yours come with a block connector & a few inches of loom?
Posted: Thu Jun 10, 2010 12:53 am
by lpgimports
Shouldnt be that hard to work out with a meter that does resistance. I used to grab any out of old mazda's in scrap yards UK Mx5's the 323 etc had one that was similar..
Paul
Posted: Thu Jun 10, 2010 2:40 am
by Northern Bongolow
as far as im aware any rear fog light switch must either have a light in it to say its on or a light on the dash to show its on,just something else to think about.but i stand to be corrected.
Posted: Thu Jun 10, 2010 9:03 am
by jaylee
Dean, the one that matches yours has a green ON light at the top. (Bottom pic.)
Mine in constantly pressed to on because i used it to break continuity to the earth from the spotlight relay when off, which is triggered by main beam.. (So it lights when the main beam light comes on on the dash.)
Now, its been a while since i set this up, so wire memory ain't so good.
I also rigged a red bright led in the lower back light portion to come on & show if i left my lower factory fog lights on when dark... (I'm more likely to get flashed by dazzled oncoming at night.)
My rear fog i rigged an on light in a spare lens in the dial pod.
If yer really stuck i can pull it out & run my meter over it, & try to find out what does what in a "normal" set up for the fog...?
Posted: Thu Jun 10, 2010 6:32 pm
by Dean
Thanks for the help, I'll have a fiddle and see how it goes
Posted: Sat Sep 04, 2010 10:09 pm
by Alifriendee
I have one too.
Did you find out which wire to attach to which connection?
