Knocking
Posted: Fri Jul 30, 2010 4:12 pm
by the smoker
got a bit of a knock when ever i hit a bit of a pot hole, its coming from the rear os. could this be a drop link..?
thanks
Re: Knocking
Posted: Fri Jul 30, 2010 4:25 pm
by You've Been Bongod
yes sounds like rear drop links if you changing them do both otherwise other side will start knocking
Re: Knocking
Posted: Fri Jul 30, 2010 4:52 pm
by missfixit70
Check the anti roll bar bushes & brackets while you're down there.
Re: Knocking
Posted: Fri Jul 30, 2010 9:33 pm
by the smoker
steady on ive only had her a week.. where are they
Re: Knocking
Posted: Fri Jul 30, 2010 9:37 pm
by missfixit70
34-156A & 28-155 on here -
http://www.lushprojects.com/bongopartsm ... mgno=.html - 2 of eac on front & rear anti roll bars, these & droplinks are common issues.
Here's the drawing for the front -
Re: Knocking
Posted: Sat Jul 31, 2010 6:03 am
by helen&tony
Errrr...After changing all said components front and rear, I still had the knocking noise???....Twas a loose spanner in a cardboard box
Re: Knocking
Posted: Sat Jul 31, 2010 12:39 pm
by the smoker
thanks you all
