Newbie questions on fitting coolant system alarms
IggleDiggle
Post by IggleDiggle » Thu Aug 12, 2010 11:32 am
Ive just come back from a two week trip in the bongo, and glad to say no issues. However, after reading some of the horror stories on these forums, I am keen to get some sort of alarm for the coolant system.
I am thinking of getting a low coolant alarm and a TM-2/or the Bongo Gauge Mod. After reading the factsheet on the coolant alarms I am slightly confused on a few things and hope someone can help.
1. One of the cons of a low coolant alarm is:
Quote from the factsheet:
1) If you have a leisure battery fitted, it will have to be removed (then replaced) to be able to fit the sensor in the tank.
What does this mean. Does it mean, i need a different leisure battery, or does it mean, take out, do the install and then put back in?
2. Where would I buy a TM-2 temperature guage from?
3. Where are the Bongo Gauge Mod details that are mentioned in the factsheet?
4. I like the idea of fitting a mason alarm, how difficult a job is it?
Thanks in advance for any help on these questions.
Triple/R
Re: Newbie questions on fitting coolant system alarms
Post by Triple/R » Thu Aug 12, 2010 11:37 am
Eyup~taking the leisure battery out is to gain access to header tank so it can be drilled to insert probe in~it's not possible to drill probe/hole with battery in~when finished reconnect same battery.
Coolant alarm's are obtainable from Hadyn Callow (look in members area) & he's got a choice of different models.
Regards Ray & Christine
Post by haydn callow » Thu Aug 12, 2010 11:40 am
Go to the web shop below or phone 01458 270230 for a chat about all the alarms / Mods that are available....and members discount.
Gripped
Post by Gripped » Thu Aug 12, 2010 1:26 pm
Check out the ESTC review on the factsheets. This shows photos of the coolant probe fitting on the header tank and also the location of the probe for the temperature alarm. The ESTC is a combination of the coolant alarn and temperature alarm in one, simple package, which is why I went for it.
flipflop
Post by flipflop » Thu Aug 12, 2010 8:23 pm
i have a coolant alarm , came with the van, its attached with a double lighter socket. Anyone know what make/model this is?
cheers
Post by missfixit70 » Thu Aug 12, 2010 8:25 pm
Sounds like Haydn Callow's low coolant alarm mk3? don't think it's produced anymore, could be wrong though.
Post by haydn callow » Thu Aug 12, 2010 9:01 pm
If it plugs in the ciggy socket and also provides 2 x extra sockets then as Kirsty points out ...that is a Mk 3 Low coolant alarm....only about 10 were produced so you have a rare one there and avid Low Coolant Alarm collectors will be offering you huge amounts of "dosh" for it..
I would hang on to it and pass it on to the grandchildren to put in their Bongo....
flipflop
Post by flipflop » Thu Aug 12, 2010 9:18 pm
yeh it goes in the cig socket and provides 2 cig sockets , very useful for satnav and phone lol
rare?! no wonder i couldn't find anything about it
1st morning after I bought the van, I turned the key and the alarm went off (ears bled !!) I was panicking!!
rang the previous owner who was concerned until he asked was i parked on a hill ! :oops: :oops: :oops:
we live an learn lol :shock: :roll:
Post by haydn callow » Thu Aug 12, 2010 10:08 pm
Shouldn't go off even on a hill....put a bit more coolant in....that should shut it up.
IggleDiggle
Post by IggleDiggle » Fri Aug 13, 2010 6:05 pm
Thanks everyone, I will have a think of the best way to go. Haydn do you give any discount to members. Also why is there a difference in price between your site and the members shop on here? Are they a different model?
Post by haydn callow » Fri Aug 13, 2010 6:17 pm
Hi...same item but you do get a bit of discount from me.
Andyf
Post by Andyf » Fri Aug 13, 2010 6:31 pm
I'm new to the Bongo world aswell and was wondering is the v6 prone to cooling problems too and would people recommend an alarm for that?
www.bongodecals.com
Manufacturer of quality replacement decals for Mazda Bongo's and Ford Freda's
Post by haydn callow » Fri Aug 13, 2010 7:03 pm
I now run a V6 and have fitted temp and low coolant alarms......the hoses etc are the same "old" age as any other Bongo so these things can and do happen
