Page 1 of 4
engine wont turn off
Posted: Sat Aug 14, 2010 5:36 pm
by flipflop
help !!!
my engine wont turn off have taken keys out
please need help
07899995480
Re: engine wont turn off
Posted: Sat Aug 14, 2010 5:49 pm
by Sharkojoints
Check the stop solenoid:
Nr 24-3002
Should activate with 12v across it. You could try giving it a tap of encouragement, or unscrew and operate manually!
eta That's a drawing of the diesel pump, living under the driver's seat, in case it's not clear!
Do a forum search for "stop solenoid" and all will become clear:
http://www.igmaynard.co.uk/bongo/forum/ ... mit=Search
Other methods of stopping engine:
1. Disconnect fuel pipe feed to fuel pump
2. Block air intake
I'd go for nr1 if I had to.
HTH
Posted: Sat Aug 14, 2010 6:12 pm
by Northern Bongolow
mechanic on scheene now guys and girls
Posted: Sat Aug 14, 2010 6:29 pm
by flipflop
who doesn't know what he is doing!!!!
Posted: Sat Aug 14, 2010 6:36 pm
by mikexgough
flipflop wrote:who doesn't know what he is doing!!!!
:shock:
Posted: Sat Aug 14, 2010 6:39 pm
by flipflop
The mechanic that is here! :roll:
Posted: Sat Aug 14, 2010 6:43 pm
by wormey
:shock:
Double :shock: :shock:
Posted: Sat Aug 14, 2010 6:51 pm
by integraR
C02 fire extinguisher aimed at the intake should do it, if the turbos leaking oil then good luck but it prob would have gone bang by now if it was that.
Posted: Sat Aug 14, 2010 6:52 pm
by wishmaster
wormey wrote:
:shock:
#-o Who's the 'mechanic' :?:
Izzy
Posted: Sat Aug 14, 2010 7:00 pm
by flipflop
just a guy from my insurance company, don't think they usually come across bongos
Posted: Sat Aug 14, 2010 7:02 pm
by missfixit70
All he's got to do is disconnect the fuel line - or can't he find the engine #-o :lol:
Posted: Sat Aug 14, 2010 7:08 pm
by flipflop
tried everything on here and more and the bugger still wont turn off!!
Posted: Sat Aug 14, 2010 7:11 pm
by Sharkojoints
flipflop wrote:tried everything on here and more and the bugger still wont turn off!!
Blimey - it even runs with the fuel line disconnected? I'd keep it quiet - you might be on to something big! :lol:
I reckon you might win the mpg thread if you play your cards right... :wink:
Posted: Sat Aug 14, 2010 7:13 pm
by missfixit70
If it's got no fuel going to it, then it must be consuming the oil from the sump, you need to stop the air getting in, best way may be to go under the passy seat where the turbo is disconnect the plastic u bend on thr front of the turbo & block the air inlet to the intercooler/engine. If it's left to run it will go bang as it will have no lubrication, co2 extinguisher suggestion may be worth trying cos you want it stopped quick.
Either that or the mechanic ain't stopped the fuel going in?
Posted: Sat Aug 14, 2010 7:27 pm
by flipflop
Thanks for all your help guys and girls, they have finally got it to stop by blocking the air intake!!
