Hi Im heading down to the hull show next week and wondered if there are any garages with bongos for sale / exchange close to the area?
Woody
Bongos for sale
Moderator: Ian
Re: Bongos for sale
you could stop off at wellhouse leisure, http://www.wellhouseleisure.com/ just off the m62, in huddersfield more expensive and mainly do converted, then after that you could call at Elams in mirfield, http://www.elamsofmirfield.co.uk/ which are not a converter and at a guess would be cheaper for an uncoverted but still get some tidy bongos in then back on the M62 back on your journey to Hull
Good luck with the search, and keep us posted
- mister munkey
Re: Bongos for sale
Hiya Woody!
In the market for a second Bongo again?
I work in Hull during the week & must admit its a bit of a commercial Bongo dessert. If you find any private sources round that way I'm more than happy to do a pre-check once over for you to make sure its worth a look. Failing that I'll meet up for a lunchtime pint or some such.
Whats the show?
Whats the show?
Re: Bongos for sale
You could try giving Charles at Durham Direct Imports a call to see if he has anything in just now. May be worth a detour on the way down to Hull if he has. Will we be seeing you in Glencoe on 25th / 26th Sep?
Re: Bongos for sale
or pop over to Wheelquick in Wigan - it isn't that far once you are in England
- dandywarhol
Re: Bongos for sale
Any vans there you could recommend 'Cat?mobilecat wrote:or pop over to Wheelquick in Wigan - it isn't that far once you are in England
Re: Bongos for sale
each and every one of themdandywarhol wrote:Any vans there you could recommend 'Cat?mobilecat wrote:or pop over to Wheelquick in Wigan - it isn't that far once you are in England
Re: Bongos for sale
just looking Mr M, when in Hull. PM me for that lunchtime pint.
Going down for the industry caravan show at cottingham on the 7th & 8th, inspecting the 2011 stock and in no way is this an excuse for a piss up.
thank you all for responding.
will contact these garages.
