Engine tuning and/or re-map?
Posted: Fri Sep 17, 2010 11:23 am
by sniperFM
Has anyone had to take their bongo for a tune up, if so, where did you take it, cost etc???
I have recently had a new cylinder head blah, blah, blah and feel that she is running a bit rough now since!
Also, has anyone ever had the engine remapped for greater output?
Thanks.
Re: Engine tuning and/or re-map?
Posted: Fri Sep 17, 2010 12:37 pm
by scanner
sniperFM wrote:Has anyone had to take their bongo for a tune up, if so, where did you take it, cost etc???
Thanks.
If it's a diesel it doesn't have a map to be re'd.
If it is running rough after having a new head, it sounds like something (timing maybe?) wasn't done right - you need to sort that out first.
Posted: Fri Sep 17, 2010 1:01 pm
by mikexgough
Timing of different parts is the utmost you can do.....and diesel pump timing, when spot on makes sooo much difference...
Posted: Fri Sep 17, 2010 4:40 pm
by skater
can the pump be " turned up " for more oomph?
and/or turbo " turned up ", ( to 11? )
Fuel economy would be worse but just wondering.
