Radiator advice and a bit of a story...
Posted: Thu Sep 23, 2010 8:16 pm
Mr bellybongo here (not the Mrs)
Well - Phil in Wolverhampton did a sterling job fixing our Bongo cooling problems (hes worked on ford rangers for years and set up his own repair shop / mot station off Cockshut lane (no sp:D)- will pm phone number if anyone needs a reliable mechanic as I would recommend))
We went to Cornwall - did full tour - , and back with no leaks at all... (in the end we replaced thermostat and waterpump) so I guess we were lucky top have a couple of minor cook ups without warping heads ./ blowing gaskets.... but
Today - when checking the water, it had lost about 1/4 pint. :
I checked the water system (which I now know very well as I have replaced alot of pipes and stuff now!!) and the radiator is leaking from the crimp between the plastic top and the metal.
I searched this forum and looks like there isn't a repair. Have tried epoxy putty but that has only reduced it....
So..... question is - best place to get a rad,, expected costs - good and bad ones.... are they easy to fit yourself??>
