V6 '99 - Digital or Analogue Odo ?
Posted: Fri Sep 24, 2010 1:46 pm
by flossie
Hi does anyone know which this is likely to have ? Can't tell from the pics the importer has mailed me
Liz
Re: V6 '99 - Digital or Analogue Odo ?
Posted: Fri Sep 24, 2010 2:40 pm
by Northern Bongolow
haydn should be along soooooooon
Posted: Fri Sep 24, 2010 4:06 pm
by haydn callow
Analogue !! on mine
Posted: Fri Sep 24, 2010 6:08 pm
by scanner
Surely ALL odometers are digital - as they only show digits.
Does Flossie mean cable driven or electrically driven?
If so - I'm fairly certain all Bongo Speedos and Odometers are electric as that is how the conversion chips work.
Posted: Fri Sep 24, 2010 6:36 pm
by haydn callow
I took it to mean...Numbers revolving...or....LED type display
Posted: Sat Sep 25, 2010 10:29 am
by 2sticks
The speedo head is driven directly from the gearbox frequency sensor.
With standard wheels and tyres, f = 100 Hz = 70 KPH. (linear).
All conversions, ie. counters for odometers and digital to analog for the
speedo needle are done electronically within the speedo head.
Posted: Sat Sep 25, 2010 12:28 pm
by scanner
haydn callow wrote:I took it to mean...Numbers revolving...or....LED type display
If that's all then I don't see what difference it makes, unless you want to "clock" it when what appears to be thought of as "digital" is reputedly much easier if you have the right computer etc.
Posted: Sat Sep 25, 2010 11:45 pm
by flossie
This came from one of the importers fact sheets ... I forgot they are general Jap importers as I'm so Bongo focussed right now ... Sorry !!
